for turbo apps why carb style intakes
Old 12-07-2006, 12:44 PM
bumpin_records's Avatar
Default for turbo apps why carb style intakes
I been searching and trying to find out why peeps go with the carb style intake over the ls6? Seeing guys running 8.50's with the ls6 like twntrboce he told me if im not planning on spinning my engine over 7k i dont need the carb style intake well i dont know if im planning on spinning my motor that high hope i dont have to . But he is running dayum good and there are others also with the ls6. So is it that guys go with the carb intake just so they dont have to do it again when they go faster? If so that makes sence meaning what will i loose running the carb style vs the ls6. Before you guys ask im running a 370ci motor planning on a pt 91.5 th400 so whats your imput on this go ahead and get the carb stlye or go ls6
Old 12-07-2006, 01:19 PM
KraZy's Avatar
I think the advantage of running a carb intake was getting an even amount of air to each cylinder.
Old 12-07-2006, 02:10 PM
phildo's Avatar
Do a search. I started the same thread and it got 50 posts of answers. No real benefit for the switch.
Old 12-07-2006, 02:20 PM
prostock_bigblock's Avatar
Thats one reason, the other reason is also fuel disturbuation.
Old 12-07-2006, 02:23 PM
KissMySSo1's Avatar
i dunno why everyone says theres no power diffrence. mine made a huge diffrence.
Old 12-07-2006, 02:35 PM
Talk about it and share with us ur experience, and show us the difference.
Old 12-07-2006, 02:59 PM
Dumb Ass Vette Moderator
ls1290's Avatar
What where your gains and what did you switch from?
Keith
Old 12-07-2006, 03:08 PM
NA$TY-TA's Avatar
My reason was better air and fuel distrabution....
Old 12-07-2006, 03:10 PM
ls1290's Avatar
Fuel distrabution..... are you running a carb?
Keith
Old 12-07-2006, 03:16 PM
7 Second Club
ty_ty13's Avatar
im curious about the "fuel" distribution as well
Old 12-07-2006, 03:19 PM
Bird-Of-Prey's Avatar
This is correct. It's not for power reasons but for safety. The #7 and #8 cylinders are the first to go lean with the LSX design and alot of guys were popping their motors because of it. The carb style has air coming in from the top and gets more evenly distributed. That's the reason I switched.
Old 12-07-2006, 03:21 PM
If your not running a carb how can fuel distribution have anything to do with it? Fuel is injected directly into the cylinder.
Old 12-07-2006, 04:08 PM
NA$TY-TA's Avatar
I meant just air... i did a copy and paste fast lol
Old 12-07-2006, 04:22 PM
im running fuel imjection well im leaning twards the carb style.
Old 12-07-2006, 04:27 PM
TINKRD's Avatar
i plan on doing the carb intake w/ my setup. from reading the air distribution is argueable b/c the runners are not equal length.
another benefit though is you can run a 90mm TB instead of bottle necking the boost w/ a ls6 throttle body.
Old 12-07-2006, 04:58 PM
SSilverSSurfer's Avatar
you switched from your FAST to the carb style
Old 12-07-2006, 05:17 PM
Never had a FAST. I actually had a BBK when I was using nitrous. When I decided to go turbo I sold it and bought a Victor Jr. with fuel rails and a Aarons elbow. I do have a FAST 90 TB though. Wish I didn't but I do.
Old 12-07-2006, 05:46 PM
LS1Tech Sponsor
Slowhawk's Avatar
I'm sold on the Carb intake setup. Made the switch many times,then the cars could be tuned leaner without affecting #7+#8 cylinders.On low HP cars it makes little difference(under 600rwhp) but they start to shine in the 750rwhp+ range.
Old 12-07-2006, 05:48 PM
TINKRD's Avatar
awesome for the 800+ guys
Old 12-08-2006, 10:38 AM
koji777's Avatar
Is it safe to say that this intake will fit under stock SS hood?
Quick Reply: for turbo apps why carb style intakes
