4l60e overheating
Old 12-08-2006, 09:26 AM
sroach20's Avatar
Default 4l60e overheating
my 4l60e is getting hot in stop and go traffic. when im cruising it stays perfect, even at high speeds. when i enter a neighborhood and have to stop alot it starts getting really hot, it got to 230 before i shut it off one time. my transmission feels like it is running perfect, it shifts like it should. i changed the filter and the fluid did not look burnt. there are no codes or anything. anyone have any idea what the hell is going on?
Old 12-08-2006, 09:53 AM
Joel_SS's Avatar
Do you have a tranny cooler on it?
Old 12-08-2006, 10:00 AM
jmm98LS1's Avatar
...and if so, how/where do you have it mounted?
Old 12-08-2006, 10:16 AM
LS1Tech Sponsor
performabuilt's Avatar
I was going to say if your runing through the radiator and do not have and external cooler you trans temp will always be higher in thouse conditions that engine temp .And it hot weather the engine temp hitting 230 would not seem at all unreasonable .
and a 230 trans temp may be a little warmer than desired but its not going to kill anything imediatley only continual long term
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 12-08-2006, 10:35 AM
sroach20's Avatar
ive got a hayden rapid cool good for class a motorhomes towing up to 10,000. i even replaced it to see if it was clogged.
Old 12-08-2006, 07:28 PM
FLT
FLT's Avatar
You might want to try a cooler with a fan.
Old 12-08-2006, 08:00 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
In addition: Bypass the radiator.
Old 12-08-2006, 08:46 PM
Figz Z28's Avatar
Id buy a cooler and a deeper pan.
Old 12-10-2006, 06:48 PM
sroach20's Avatar
i took it out again and started driving around to let it get warmed up. it started to make a grinding and vibrating noise from the tranny area. it sounds like its the torque converter. could the torque converter failing cause the fluid to get hot. it only vibrates in the low rpm range.
Old 12-10-2006, 07:04 PM
LS1Tech Sponsor
Yes a failing converter can cause extreme overheating and subsequent damage to trans .
In fact in cases of converter clutch failure they can actually block cooler flow and cook everything , If you can remove the inspection plate and try and veiw the converter in the same area the bolts go in on the flat for signs of heating discolored or flaked paint or worse bluing of the converter surface , Also smell fluild for a burnt smell
__________________
Call 888-744-6542
Quick Reply: 4l60e overheating
