Who removed steering linkage on header install?
negative on pacesetters also.. Leave it in. If you do need to take it out for some reason, its real easy like mentioned.. Just 1 bolt and it will swing away enough to put pretty much anything in
-Jeff
-Jeff
I just installed my Pacesetters a couple months ago and I had to just slip the linkage off....no big deal. Also had to grind the tab on the block a little. I was surprised I had to do either of those after reading so many posts about NOT having to do these with Pacesetters. I agree each car is slightly different. Probably could have 'persuaded' them past the linkage but I didnt want to scratch the coating off....but the tab needed to ground a little either way. I did them on a lift which made things a ton easier.
