Burnt out Signals Anyone?
Well my problem has been going on for well, since i bought my car. I cant seem to keep my turn signals lit. To begin with, i had the stock amber corners and my right corner seemed to collect moisture thus causing the signal bulb to short/burn out.. at least i think. So, i bought two aftermarket housings. I installed them and both of them collected moisture also burning out my right corner. Now, two questions 1) has anyone else had this problem? and 2) how did you fix it?
thats tends to happen to almost all f-bodies. gm shoud do a recall or something. it happens to me whenever i wash my car one goes out a day or to later.
Yep, when I got my clear side markers I had issues with water collecting in them too, mainly just the passenger side one. The gap between the front bumper and the headlight there is bigger than on the driver side so water kept coming in through top where the bulb plugs into the housing. I put silicone all around the edges of the housing, and also put a thick bead of silicone around the hole in the housing that the big bulb plugs into, and also put silicone on to the thingy that holds the bulb, then siliconed again all around it once the bulg was inserted into the hole. Haven't had any problems since.
