Dissapointed in my new HAL QA1's
whent ot track for frist time today with the new shocks on car, witch are
HAL QA1's R searise with 300 pound springs. had the shocks on 1. well my
60ft did not change at all, they was the same as when i had my stock stuts and springs on the car. and my times didnt change either.
damn skipper,don't sugar coat or anything another guy who tells it like it is,now i don't have to feel so bad when i do it.
SILVERZ- the hal's did'nt seem to help me much either when i added them. now that i have alot more power and tq,i'm sure they are helping me now. i'm sutting 1.42 60's on the motor,m6 @ 3,700lbs w/me in it.
well i tried from 4 to 1 to day on the settings and they all netted same thing.
my stock shocks and springs did the same 60s as these did today, no improvements.
and im sorry you dont like my grammer or spelling MR. English teacher
Originally Posted by skipperbisket
having them set on 1 probably isn't the most optimal setting... try typing your posts in word and spell/grammar checking before you post.
dont know how much power you got, but i beleave i got anough to where these things should work at least a little bit over what i got out of the stock ones. but they didnt
stock shocks and springs was 1.68 to 1.70's, new set up to day with ajustments from 4 to 1, 1.75 60's all day
Originally Posted by FloydSummerOf68
What kind of 60's are you currently getting?
7 Second Club
whats your pinion angle? and what tires are you using? are u a A4 or m6... what converter do you have or what rpm are you dumping the clutch...
there is too many variables to say it doesnt work.... no one said that the QA1s produce miracles- just slap them on and turn ***** and they work....
its a race car..... and race cars take many, many runs to get dialed in...
im gonna guess your tires arent up to par.... i cut 1.53's with stock shocks and some 28'' MT DR's with BMR Xtreme TA, Sway bar, sfc, and Lca's
7 Second Club
I know this is a little off topic, but can you tell me how the R series shocks drive? I'm looking to pick some up and this is my daily driver.
it was spinning just as much as it whould with the stock stuff, a little off line then hook.
Originally Posted by 1QuickT-A
was it spinning with the stock shocks and springs???
ok here we go. pinion is set at -2.5, i have reloctaion brackets for the LCA's and there in the 2nd hole witch puts the LCA's in a -2 decline from the body of the car to the rear, just like madman as stated it should be lots of times on here,
car is a M6 tires are ET Streets 26x11.5.16's, tires set at 17psi cause that where they like ot be on my car. i leave the line around 4500rpms, as any higher the car will spin badly
and i never said they whould work miracles, but was hopping ot see just a little change, and i did not
