Anybody replaced Hatch?????????/
I did exactly what you are dooing. Mine lined up perfectly, i had the formula hatch and swaped for the high rise ta hatch. You will need some help because the bolts at the top are a pain in the *** to line up, bolt down, and hold the hatch up all at the same time. Maybe adjust the bump stops on your car or if it is not lining up where it locks loosten the lock and adjust it a little. It can be done, Good luck
The hinges on my formula hatch were stiff and the hinges that were on the ta hatch were loose and thats why i said to get help because they are a pain in the *** to hold up and get the bolts lined up, hold the hatch up, and start threading nut on there. You willl figure it out. Good Luck
