ARP Studs for Headers (Torque Specs)
Old 12-12-2006, 01:30 PM
JD_Z28's Avatar
Default ARP Studs for Headers (Torque Specs)
Does anyone know the torque specs for the ARP Stud Exhaust Manifold kit for the LS1's?
Old 12-12-2006, 02:29 PM
SS DNA's Avatar
The stud has a "bump" on it, You should put them in until it hits that. Just make it tight. Thats what I did.
Old 12-12-2006, 03:52 PM
JD_Z28's Avatar
I know that I wanted to know the specs for the nuts, Thanks.
Old 12-12-2006, 04:22 PM
Kleeborp the Moderator™
MeentSS02's Avatar
I don't think I've ever seen any published values for those...I think I read somewhere where a dude torqued his to 25 ft-lbs, but I wouldn't trust my aluminum heads against my memory. At the very least, you could just torque them to the factory header bolt specs and see if they leak. If they don't, you should be good to go. That's what I'd do.
Old 12-12-2006, 05:33 PM
JD_Z28's Avatar
Thanks bro thats just what I did, I just wanted to make sure.
Quick Reply: ARP Studs for Headers (Torque Specs)
