mls gaskets with old ls1 head
Old 12-13-2006, 04:01 PM
jeejee's Avatar
Default mls gaskets with old ls1 head
is this the reason the MLS doesn't work with this type of head ?
and would it help when i weld it and skim the head ?
thanks, Jeejee
Old 12-14-2006, 05:39 PM
jeejee's Avatar
nobody ?
Old 12-14-2006, 06:25 PM
GuitsBoy's Avatar
If youre really bent on doing it that way, you can weld and mill it, however from what I understand, filling aluminum in requires heating quite a bit with a rosebud and some careful welding to keep from developing voids.
I think its easier just to use gaskets with the notch.
Old 12-14-2006, 08:12 PM
N4cer's Avatar
Yeah, that notch is why you can't use the GM MLS gaskets. Gotta use the composite ones.
Old 12-15-2006, 12:53 PM
jeejee's Avatar
yeah i know it would be easier to use the composite, but i plan on using some serious boost, so i would like to use the (cheap) GM MLS gaskets
Old 12-15-2006, 03:08 PM
Studytime's Avatar
I don't think you can use the words "cheap" and "boost" in the same sentence (well, maybe this one) . Those heads don't look too special from the pictures, I'd suggest selling them and trying to get a set of 241/243 castings if you're dead set on getting the GM gaskets.
You could also get the $30/each AZ composite gaskets that are .042" compressed thickness. Those will work with your notche head or with the latter castings.
Ben T.
Old 12-15-2006, 04:40 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
Ben T.
I've never heard of AZ composite gaskets, do you have a link for them?
Old 12-16-2006, 01:04 PM
jeejee's Avatar
Ben T.
well cheap is relative, for my cosworth 4 cyl. turbo engine the cheapest MLS with acceptable quality is $503 each,
and selling these heads: allmost nobody here has a Ls engine series car, let alone interest in buying a used set.
And for me getting a 241/243 casting provides the same problem....
I have these heads and when possible will use them.
i don't like composite gaskets, they tend to blow/ deteriorate quite fast when abused
Old 12-16-2006, 01:33 PM
GuitsBoy's Avatar
AutoZone maybe?
