What's the difference between the F-body and Corvette Powerbond UD Pulleys?
Well seeing as they accidently misboxed one and sent me the vette one...
the vette one will not work on a f-body. The f-body pulley is wider from front to back than the vette one, plus PB underdrives both the ac and acc pulley on the vette model at deifferent ratios, the f-body one both are underdriven the same amount.
to save you some hassles unless you are willing to either change out all of your accessory pullies the vette one will not work on a f-body.
Originally Posted by gnomee
Where is your power steering pump? Don't have one? Or is the resevoir not on the pump?
The alternator is located on the bottom right. A quick confirmation would be greatly appreciated as I need to get it ordered!
Thanks everyone.
