truck manifold kit... please help
so i got my shortblock back in and i threw a set of heads on it to see how close everything fits. well the motor is sititng too close to the passenger side. im using a bmr tubular k member and poly mounts, and the flange on the truck manifold is almost touching the frame and the stud on the manifold is almost touching one of the bars on the k member. any ideas? i'll have pics up very soon
when i put the motor mounts on the block i didnt pay too much attention, by any chance can you put then on wrong? i didnt think you could but i didnt really look at them either
well i tryed fitting the 6.0L manifodls when my stock k member was in and i had a lil over 1/2 in clearance to the frame rail. now the bmr k member is in and theres no where near the same clearance
im thinking its possible the k member is tweaked a little. i mean it bolted in fine no problems maybe the motor mounts are welded on straight. when i put my trans crossmember on i did have to fight it a little bit had to push the trans towards the drivers side which would push front of the engine towards the passenger side
Restricted User
What year are the manifolds?
I have 02s and 04s sitting here and they have the flanges in different locations.
This might be your problem.
nah im going to do a single lol i just gotta get this damn thing sitting in there right. im stumped right now. the only thing i can think of is the k member but i dont know how i would check that besides swapping it for a different one and seeing if it sits the same
