Help! What goes behind my intake manifold?
Old 12-19-2006, 10:45 AM
1QWKT/A's Avatar
Default Help! What goes behind my intake manifold?
Looking at the engine from the back (it's on a stand) to the left of the EGR there is a U shaped dip in the manifold with a bare bit of block exposed with a threaded hole. It looks like this hole runs into the oil galley which leads me to believe maybe the oil pressure sensor goes here? But I can not find anything in my endless boxes of disassembly parts that would fit there. Anyone know? If someone has a picture of that part of the engine I can point out which hole I am speaking of
Old 12-19-2006, 10:49 AM
1QWKT/A's Avatar
Also, the opening to the right of the EGR of similar shape, smaller size, that is A.I.R. correct?
Old 12-19-2006, 11:40 AM
Fire67's Avatar
Looking at the back of the motor, the hole on the left of the EGR in the block is for the pressure sender... Kinda.
The hole gets a hex shaped elbow, then another hex elbow threads into that, finally the pressure sender gets threaded in and rests at a 90* angle to the intake-to-block sealing flange.
To the right of the EGR? Could you be more descriptive on that one?
Old 12-19-2006, 01:03 PM
1QWKT/A's Avatar
It is an opening similar in shape to the EGR. Two bolt holes w/ one hole in the middle. Couple inches to the right of my EGR which I have already blocked off.
Old 12-19-2006, 01:04 PM
1QWKT/A's Avatar
Anyone have a picture of this "hex-shaped elbow" or a picture of these parts assembled on the block? Thanks for the help so far, I'm no longer completely clueless
Old 12-19-2006, 01:24 PM
buffman's Avatar
Old 12-19-2006, 01:28 PM
ulakovic22's Avatar
You are correct it is the AIR passage. There is a tube from the exhaust manifold that runs to the back of the manifold.
Old 12-19-2006, 05:32 PM
1QWKT/A's Avatar
Sweet! Printed out about 20 pictures from shbox.com, I should be all set. I'll post up a video when I get it running again. As always, thanks for the help guys!
Old 12-20-2006, 09:15 AM
Fire67's Avatar
Cool, glad you got it figured out. And thanks Buffman for posting that pic. Should make it very clear as to what Im calling a 'hex shaped elbow'.
