Idle reads lower than HPscanner
Old 12-19-2006, 11:31 PM
618HAWK's Avatar
Default Idle reads lower than HPscanner
Have a problem where my actual idle. It reads300-400 rpms lower than what is indicated on HpScanner, also tryed auto tap. Still reads low.
Any ideas...........?
I think it might be due to the fact that I have not been able to do the idle relearn.
Reason why is the a/c needs to be charged, in order to get the system to activate the clutch.......... No pressure in the system..
Old 12-20-2006, 10:05 AM
greatwhite99's Avatar
are you talking about the dashboard tach?
Old 12-20-2006, 10:08 AM
618HAWK's Avatar
Yes Dash tach reads 300-400 lower than HpSanner Tach and a Auto Tap Tach.
Old 12-20-2006, 10:30 AM
stock tach is less than 100% accurate especially in 1st gear. Use an aftermarket tach for better results.
Old 12-20-2006, 10:37 AM
LS1TECH Sponsor
foff667's Avatar
werd, even at idle mine was always off by ~200 rpms.
Old 12-20-2006, 10:55 AM
618HAWK's Avatar
I can live with a 100 or so, but this is close to 400. Just bothers me to see it sit there and read 200 rpms at a light. When I know it is around 600.
Would this cause problems for any other of the pcm functions when it comes to tunning?
What would be causing this?
Anything I can do to correct it?
Not going to install another tach.
Old 12-20-2006, 11:01 AM
LS1TECH Sponsor
foff667's Avatar
ahh, yeah thats not good that its sitting at 200 rpms at idle lol
Old 12-20-2006, 11:03 AM
618HAWK's Avatar
Ya tell me about it, dont like it one bit.
The only thing I can think of is the relearn needs to be preformed.
Old 12-20-2006, 11:47 AM
Ira
Ira's Avatar
Originally Posted by 618HAWK
Ya tell me about it, don't like it one bit.
Pull the cluster, remove the plastic face and replace the cluster, start the car, remove the needle and put it back so it points at the correct RPM. If you're lucky it will then be correct everywhere, if not you will have just moved the readings that are really wrong somewhere else. Nothing you can do to the PCM should have any effect on the cluster, at least not on a F-Body.
Ira
