did I ported my stock LS1 heads correctly? see the post.
did I port my stock LS1 heads correctly? see the post.
i ported my stock LS1 heads here what i did :
1- matched the bowls to valve seat for both intake and exhaust while keeping the bowls original shape.
2- narrawing a little the valve guide boss.
3- didn't touch the short side radiaus or the floor of both intake and exhaust just polished them when i finished porting.
4- removed the rocker arm stud hump that is in the intake port until the rocker bolt threads appear and the wall of the rocker hump is even.
5- smoothed the roof of intake and exhaust and matched it to the bowl.
6- didn't realy port match the intake and exhaust openings to the gaskets.
7- i used stock valves.
correct me if there is any thing?
thanks.
thanks.
I'd love to answer, but I've never ported a set of heads before. I just want to say my hat is off to you for jumping in and going for it!
Anyways, here's a free bump to the top for you.
Originally Posted by 01FireTurd
first part of #3 wrong,# 6 wrong ,and just my opinion if you have to ask if your heads are ported right then they are probably not, but more knowledge and practice will help
FWIW, sounds like you couldnt have hurt flow, that was my main concern. I figured I Wouldnt get pro performance or #s, didnt expect to. but just trying to improve the flow w/o paying the cash for a pro job. and ofcourse like you I wanted to learn about it.
you should post some pics if at all possible.
good luck
it's probably a good thing that you didn't mess with the short side,since your just starting out.you can really mess up quick on the short side if you don't know what's going on.now get a good valve job.that will also make or break a good head...
sorry for the wait. the problem is that the heads now are assembled and i don't want to dis-assemble them i just did valve job to them and milled them 0.004" to 0.005".
i don't have camera (sorry for that) to get some pics for you but i will try to get some pics but it may take time until i find a camera to get pics for you since i'm broke now and i can't buy a new camera.
if i didn't port the heads correctly that doesn't mean i ruined them i think the heads will perform OK since i didn't touch the short side radius and the floor where it might hurt flow if you port them the wrong way. because i ported before a set of stock LT1 heads and i got good result with them i applied the same concepts i did to the LT1 heads to the LS1 heads. is that correct applying the same porting concepts to stock LT1 heads to stock LS1 heads?
Theres nothing wrong with not gasket matching or messin with the port floors. Port floors are tricky and if left alone no harm no foul, gasket matching isnt what you want to do any way- port match. If your header gaskets are 2" in diameter then its gonna be a problem when ya hog em out for 1.75" headers, see my point. The short side radius can be tricky too so you need to atleast smooth it out and make it more roundish to help it blend into the floor straight away
i took pics of the LS1 heads but i need a way to upload them to the internet any one knows how?
i only took pics of one intake port and one exhaust port because the heads are assembled and i didn't want to miss with the heads since i just did a valve job to them and assembled them. some pics are with bad quality, sorry for that.
Bo White, i feel good you are with me in what i did to the heads. i think even if i didn't port the heads as proffessionals do at least i didn't ruined the heads, i think i picked up some cfm in both intake and exhaust. i will use TSP 233/239 112lsa revision 2 cam with these heads.
http://imageshack.us/
http://www.porteighty.biz/uploader/
there ya go buddy. browse, select, upload, copy/paste the message board picture one. or the link. either way.
those pics r in the middle of my work, not the final finishing. and I think those should give u an idea on how to shape the guides.
I will post the intake and exhaust ports later.
abdullah, did you use a sand paper drum to finish the surface? looks like you used a grinding bit only. maybe its just the pics quality? it should be smooth after you finish. also Im concerned that you didnt wash the heads off/out good enough after all your work, before assembleing the valve/springs. those things need to be VERY clean before you bolt them back on to keep from contaminating the oil/coolant with metal dust. that would be bad. try this test. get a can of brake cleaner and a rag, spray the cleaner on the rag and wipe the heads off. it should not get the rag dirty. if it does, clean them off/out again. using a brass wire brush thats shaped like a tooth brush and some good warm soapy water. if you can use a blow gun to blow out the heads after washing them.
prostock_bigblock, thanks for the pics. did you port the floor of the intake? if so how? how aboout the short side radius if i'm porting for stock valves? i don't need to miss with the short side radius?
Irocss85, i used carbide cutter ( grinding bit) and finished the ports with 80 grit cartridge roll. when they did valve job and milled the heads 0.004" to 0.005" they cleaned the heads.
Slowhawk, how to port the port floor? also do i need to port the short side radius specialy for stock valves. about my heads i didn't do any thing to the short side radius and floor just polished them with 80 grit cartridge roll since i was porting for stock valves.
dont alter the shape of the short side, all u need is smoothing.
