Driveshaft Question
Driveshaft Question
I'm driving my car the other day and I floor it in first and then rip it into second and then a loud bang. So I pulled over and looked under my car and I snapped the driveshaft right in the middle. All I have is full exhaust and drag radials. Does anyone have any idea on what caused this? It is the stock aluminum one. Thanks
hmm aluminum ones tend to have problems unless they are balanced correctly do to the fact there not as strong as the steel ones....however one from the factory should be fine...you lucked out it didnt beat the hell out of your car....now go get a steel one and dont worry
Aluminum driveshafts aren't weaker than the steel ones. The AL shafts have thicker walls than the steel shafts to make up for the metal's "weaker" composition. The stock steel shaft is no stronger than the stock AL shaft.
Tough break man, good thing it didn't tear anything else up. Be sure to stick a DS loop in there with your new one.....you got lucky this time!
yup, sometimes, when its gonna go, its just gonna go...
i broke mine on street tires (275/40/17), with a lid and cutout. sorry to hear about your bad luck. i suggest going with an upgraded one...that being said, i picked up a stock aluminum one for $90 shipped. ill upgrade when i do the rear...
-cam
-cam
About a couple of weeks ago I noticed a rattling noise under my car when i'd be driving it. It sounded like it was coming from right under the center console. I thought it was just the exhaust rattling because I took off my catback and had the stock one put back on a couple of days before that. After my driveshaft snapped I thought maybe it was that rubbing somewhere. I got another stock aluminum one and put it on and the same rattling noise. I listened to the noise a little more and it really sounds like the ds is rubbing somewhere right after the trans, but that doesn't explain why the ds snapped right in the middle. I have to look under the car better once I have more time. I just don't know what it would be rubbing on!!
tourque arm maybe, if it cam unbolted, that happened to me, if your looking to get another ds aluminum, im selling my stock one it held throuh alot, my torque arm came loose after installing the 12 bolt and new ds, could have killed my friend.
ive personally never seen a steel ds break, ive never seen them become unbalanced and worm....take the steel shaft and beat it on the alumn. one...see which one bends first... i think he should just save his money and get a chromoly or carbon ds...
