lt1 Canton pan owners
just got the canton pan today for the Z and got to it and the damn thign dosnt fit because i didnt buy a new pickup from canton...i have a brand new melling pump with pickup from when i dropped the new motor in but that pickup is about 1.5 inches too far forward to fit in the confined space in the canton pan..what pickup do i need?
Originally Posted by 2fast97Z
wow the canton one??????????????? NO **** i meant the part number smart ***
Originally Posted by darrell hoagland
sorry to high jack your thread.were is the best place to buy the cayton oil pan at
http://www.cantonracingproducts.com/
Originally Posted by 97LT1
whats the part # for the pan you got Brett?
ok back...it's a Canton Road Race oilpan PN#15242T. This one cleared the BMR Kmember, KOOKS headers, stock pickup worked fine. Only thing I couldn't use with this pan was the low level oil sensor due to where the KOOKS primary came down.
Originally Posted by BRETTINATOR
got it down in my Jeep...gimme a few to go get it...BRB
do you just plug the hole?
Bahhhh! low level oil sensor is for sissies.
we used a hex bolt plug and still had to shave half of the hex head off to leave about 1/8" clearance between the header and hex. If I did it again I'd weld shut that hold completely, or if I ever drop the pan for whatever reason, or take off the headers I'll do the same.
I would not use the stock pickup IMO. I use the canton 6 quart pan and was able to use my low oil sending unit, but I have Hooker Long tubes.
Brett do you run 7 quarts in the pan or 6?
I do have the #15-242t(same as yours) pan with a melling high volume pump. I have run 6 quarts for a while now without a problem, extra quart probally cant hurt.
Originally Posted by 93 4mula
So the canton pickup will work with a meiling HV pump? Because I am wanting to go the same route..
melling High volume pump, and the canton pick up(cant find the part number) is what I run without a problem.
yea I was not about to use the stock drive rod with the PLASTIC conector. When I took my motor apart my dad and I saw that and were like WTF. Yea figure with the filter and all you could probaly run 7 without a problem.
I saw on cantons website the company CW oil filters, where you would just buy the filter element and reuse the metal canister. Anyone use one?
