Sponsored by: DashLynx
how do you remove rear seats?
Old 12-22-2006, 09:05 AM
Restricted User - Non Spon Soliciting
*KANDY SS*'s Avatar
Default how do you remove rear seats?
Is there any special way to do this? I am trying to get my new covers on and I need these off to do so.
thanks!
Old 12-22-2006, 11:34 AM
Kleeborp the Moderator™
MeentSS02's Avatar
There is one bolt that holds the bottoms in place, and it is at the bottom of the front lip of the cushion, right in the middle. Once you get those out, it should be pretty easy to see the two bolts at the bottom corners of the seat back that hold that in. You'll just need to take those out, and remove the seat belt guides from the back.
Old 12-22-2006, 02:06 PM
SS4Matt's Avatar
wow i just finished putting my whole interior back in like 3 minutes ago so it's fresh in my mind. for the bottom part of the seat, there's a 13mm bolt that is located towards the center on the front of the seat.
for the back rest part, there's a 13mm nut on either side of it where it "pivots" down. if you want the back rest completely out, you're going to need a small torques bit to remove the belt guides.
Old 12-22-2006, 09:08 PM
6LITEREATER's Avatar
Looks like they've got you "covered"
I figured you wouldn't be able to wait too long to put these in !
Old 12-23-2006, 12:05 AM
*KANDY SS*'s Avatar
now, the ? is...where the hell do I get a hog ring pliers at locally?
Old 12-23-2006, 12:11 AM
I thought Arizen rears came with them??? I would think you could make regular pliers work...
Old 12-23-2006, 12:15 AM
*KANDY SS*'s Avatar
nope. I think if I ask him he can get some to me. I know they are pretty expensive when you buy just one. I think I can get the seat back on without them (they don't need them) but for the bottom cushions, its a must have.
Old 12-23-2006, 12:17 AM
Here's a pic of some hog ring pliers with a hog ring in them:
I think you could, with a steady hand, just use regular pliers...
Quick Reply: how do you remove rear seats?
