Hi-flo problems, go figure! (pics)
Old 12-25-2006, 01:30 AM
2002/Black/SS's Avatar
Default Hi-flo problems, go figure! (pics)
the crossover is hiting my powersteering lines, i bent the **** out of them and they still hit it, im really pissed. and i cant figure out what to do and im afraid i mesed up the lines by bending them. how much can i really bend them???
3 pictures of the lines hitting the crossover:
AND as u can see i bent the **** out of them:
and here is the crank to crossover clearence (not to bad):
Old 12-25-2006, 01:43 AM
Abdullah's Avatar
maybe you need to bend the turbo system corssover itself in some way.
Old 12-25-2006, 01:57 AM
the only way to fix it using the turbo crossover would be get a new pipe or extension, which im considering
Old 12-25-2006, 07:35 AM
Runn's Avatar
Put some rubber where it touches
Old 12-25-2006, 08:35 AM
Sprayed96ss's Avatar
haha and that would last all of about 5 mins.....
Old 12-25-2006, 09:15 AM
Smearin's Avatar
Am I seeing things or is that your intercooler by the crossover?
I see the bite marks.. Dont be grabbing those lines with pliers and bending them..
Old 12-25-2006, 10:12 AM
stevieturbo's Avatar
Have you considered whacking the crossover with a hammer to create some clearance ??
Old 12-25-2006, 11:17 AM
SSilverSSurfer's Avatar
delete powersteering
Old 12-25-2006, 12:25 PM
bboyferal's Avatar
Yup...
Can't you put a "dent" into the area of the crossover pipe that's a problem?
Old 12-25-2006, 12:43 PM
Turbo LS1 SS's Avatar
BEND those.....i have my lines infront of the alt.....put some more muscle into it...lol ..... then wrap them. you will be fine.
i had no problems with that crossover clearance
Old 12-25-2006, 12:50 PM
that was my last resort because i was afraid id break them, well m gonna go for it, but it still dosent look like theres much cleareance, ill try it this afternoon, and ill let u guys know, also my crossover at the top hits the stock fan but im hoping this will fix that to, other then that it looks pretty good
Old 12-25-2006, 12:52 PM
haha i took my fans out, thast my radiator
Old 12-25-2006, 01:15 PM
Dragframe's Avatar
=/ Kits really should be "bolt-on"
This is somewhat of a joke... but, its not as big of a deal as you are making, just bend the lines out of hte way, I had to on my kit. Your car was never designed to have a big ole turbo and a bunch of exhaust pipes under the hood. lol
Old 12-25-2006, 01:21 PM
GrahamHill's Avatar
Why cant you just take the line off and bend it into the alternator a little more? Would that work?
Old 12-25-2006, 02:09 PM
SELLSZ06's Avatar
mine are almost the same but I bent them a little more than you did and wrapped my cross over, youll be fine.
Old 12-25-2006, 06:43 PM
Brains's Avatar
You're putting a TURBO KIT into the engine bay that's barely large enough for the motor itself. You should pretty much expect having to tweak things here and there. This isn't like installing a Tornado in your intake tube, this is a real modification
Old 12-25-2006, 07:53 PM
Smearin's Avatar
Wait.....
I have a Tornado on my car... at least thats what I tell everyone the sound is..
Its a real mod...
Old 12-25-2006, 08:35 PM
67Firebird455's Avatar
You'll be perfectly fine, those lines bend relatively easy. Just don't bend them back and forth over and over again too many times or you'll run into some issues. They really are made of that material to be able to flex SOME. Other than that it looks good! Let us know how it works out!
Old 12-25-2006, 08:41 PM
ABeasst's Avatar
I bent the HELL out of those lines to make it clear and then wrapped them. thats what it takes to make it fit.
Old 12-25-2006, 10:21 PM
99Fbody99's Avatar
Why not pull the lines and replace with braided -6 and reroute them?
All the fittings are available.
Dave
Quick Reply: Hi-flo problems, go figure! (pics)
