pacesetter install write up?
Damn does anyone bother to read the stickies?? Header install is right in the sticky. Here man, but next time search and check stickies first. Exhaust install has been beaten to the ground here.
https://ls1tech.com/forums/generation-iii-external-engine/520845-mod-guide-induction-exhaust-please-read-before-posting.html
header install instructions are pretty much generic. Remove emissions pipes, tale pff coil packs, remove spark plugs, take out dipstick, take off old manifolds, put in headers. Depending on the brand you may need to cut off the aluminum tab on the block.
there is no need to remove coilpacks...
