T56... bad throwout bearing???
Old 12-27-2006, 09:35 PM
FU_I_AM_UltraZ's Avatar
Default T56... bad throwout bearing???
i've got a 2002 z28 6sd, it makes a rattling noise inbetween shifts. also, if i'm stopped and in neutral, it makes a light rattle until i put the clutch in and shift into 1st.
do i need a new clutch or is it just a throw-out bearing? maybe something else?
also, i here a humming (more like an electric motor) in 6th gear when accelerating at 60 mph.
hope someone can help me... thanks!
-Charlie
Old 12-28-2006, 08:37 PM
anybody?
Old 12-28-2006, 09:08 PM
kookamunga's Avatar
I would think the throwout bearing would make noise when you pressed the clutch since that's when there is tension on the bearing. IMHO
Old 12-28-2006, 11:44 PM
MrEddie's Avatar
I just updated my master and slave and I've always noticed a very faint buzz/rattle when in neutral with the pedal up (old setup and new), so I guess it's normal. As far as the transmission, I think that's the regular trans noise. I hear it most when letting off the gas in 5th and 2nd.
Old 12-30-2006, 03:10 PM
one thing that i have noticed is normal while cruising is when you let up on the gas and there's a clunking noise. i've had that on both my 2002 z28s and the other was an auto tranny stock 4sd.
Quick Reply: T56... bad throwout bearing???
