Lou's Short Stick on a B&M Ripper?
Well, I have a t-5 tranny with a B&M ripper shifter, anyone ever heard of a Lou's short stick being put on a B&M Ripper? I just cant stand how tall it is. Heres a couple pics.
Lou's Short stick for Aftermarket Hurst shifters (Competition Plus/Billet Plus) will fit the 1st Gen Rippers with the removable stick....
The 2nd Gen (current) Rippers have a short 1-piece stick, so you can't replace it....
Not sure about the Rippers for the T-5, but from the looks of the stick on yours, I really hope it's a 2-piece
If it is, pull the stick and measure the hole sizes and distance between the center of each hole....
Rick
Rick
I've got a near new one I got a few months ago. So its definately a 1 peice. Figures.
I wonder if I could have the stick machined down or something...
Kleeborp the Moderator™
Originally Posted by MeentSS02
I've had one of my B&M Rippers machined down (still have it, just don't use it right now) 2", so it can definitely be done. It cost me about $75 though.
What did they use to do it? And were they able to keep the same thread pattern?
Originally Posted by 98 SNAKE EATER
What parts did you break
there's 2 (horozontal) bolts holding the shift handle lever to the shifter
I sheered the top one,
so it was pivoting on the bottom one.
going back to stock (probably with a lou's short stick)
and possibly going with a McCloud or GMM when I do my clutch.
If that's the case, then you have the older 1st Gen Rippers and you can replace the tall stick with an LSS made for aftermarket Hurst shifters
Originally Posted by ckyconan2003
your e-brake prolly shouldnt be so high?, wicked seat btw
Damn...how tall are you?
I broke my B&M ripper today ;(
less than 2 days with it in (professionaly installed)
This is in a GTO. The B&M design is without a doubt the worst design I have ever seen. Their design is prone to leaking, breakage of shift handle bolts, loosening of bolts/stripping of threads and eventual complete failure of the shifter. The first time mine broke one of the bolts that yours broke. The second time it broke, I snapped the shifter shaft itself in half shifting into second gear at the dragstrip. Here is a pic. Yea, I know...tons of RTV, but I couldn't get it to seal, no matter how much I put on it.
This is how I drove home from the track.
I have heard of at least 5 other shifters snapping off in the same location. With this experience, I will do my best to NEVER purchase another B&M product.
Galen
