pacesetter vs. slp
Old 12-30-2006, 12:01 PM
nor-texLS1's Avatar
Default pacesetter vs. slp
i was checkin out some LT headers, and i found pacesetters for $280, and the slp's for around $800 summin....is there a big performance differance between the two?
Old 12-30-2006, 01:36 PM
NoCobra's Avatar
https://ls1tech.com/forums/showthrea...ight=Edelbrock
That helped me pick mine out mine.
Old 12-30-2006, 04:45 PM
2001bluerata's Avatar
There is no big power diff. between LTs, just a big price diff. Go w/ the pacesetters and take the left over 520 and finish the rest of the exhaust. If u already have cat-back spend it on something else!
Old 12-30-2006, 05:41 PM
nor-texLS1's Avatar
aight, thx fellas
Old 12-30-2006, 05:56 PM
RoWDyWS6's Avatar
im going wit pacesetters...i wouldnt pay more than 500 on LT's
Old 12-30-2006, 06:28 PM
740racing's Avatar
All depends on what you want, stainless = your gonna pay more.
Old 12-30-2006, 11:12 PM
jetlag's Avatar
I paid $519 shipped for my coated Pacesetter LTs, ORY, O2 extensions, gaskets, bolts, etc.
Old 12-30-2006, 11:24 PM
00TAProject's Avatar
374 from Texas-Speed.com They are a sponsor.....Reused the original gasket and have had NO problems what so ever.....
Old 12-30-2006, 11:29 PM
2ThouZ28's Avatar
question while this is on subject. Im thinkin of running a setup consisting of pacesetter LT'S into a 3inch pipe with one 12" bullit muffler then dumped at the rear axle....... anyone got advise?
Old 12-30-2006, 11:41 PM
jetlag's Avatar
Yeah, get a bigger bullet!
I'm doing the same setup except I bought the 18" bullet from Jegs. The smaller it is..the more loud it will definately be!
Also there would be more rasp with a smaller one?
Old 12-31-2006, 12:03 AM
Tech Resident
ChocoTaco369's Avatar
$280 for pacesetters? must be the non-coated.
DO NOT BUY UNCOATED PACESETTERS. i repeat: DO NOT BUY UNCOATED PACESETTERS.
you want the coating. it helps protect against rust, they last longer, look better and they keep your underhood temps MUCH lower. they're a far superior header. uncoated headers are junk. pacesetters, coated, are only $375. this should be a simple decision.
if you want stainless, stay away from SLP headers. they hang low, are very hard to install and scrape almost everything. kooks, QTP's and stainless works make great LS1 headers. i'd probably go with QTP's as they have high velocity merge collectors for added power and are a very proven header.
Old 12-31-2006, 12:32 AM
nor-texLS1's Avatar
thanks choco, that helped alot...what about edelbrock lt's?
Old 12-31-2006, 12:39 AM
jester177's Avatar
i bought my pacesetters the painted ones for 150 brand new i think it was 19x shipped. and from all the clearence issues with slp i wouldnt even think of them. but i dont see the point of spending more for the same product thats a little flashier if thats a word, or something that will eventually ware out anyways. for 150 i could replace that every few years if i had too. at least that was my thinking.
Old 12-31-2006, 12:48 AM
BayAreaSS's Avatar
Choco covered it very well
Old 12-31-2006, 01:45 AM
98hardtopZ's Avatar
dont be confused, stainless will not wear out, it will outlast the rest of the car. as far as the coated pacesetters go, the heat will eventually get to them so if you plan on having the car forever or for a long time, or even if you live in the north or wet climates stainless wouldnt be a bad investment. i hate to do it but if your on a budget try ebay for some affordable stainless headers.
Old 12-31-2006, 03:08 PM
SatanzWS6's Avatar
pacesetters FTW. i have had no problems with mine and i ve had em for about 4 months now.
Old 12-31-2006, 03:30 PM
nor-texLS1's Avatar
what kind of power increase should i expect from pacesetters?
Old 12-31-2006, 03:32 PM
SatanzWS6's Avatar
dont expect a huge increase. from a dig, you wont feel it as much as up high.
Old 01-01-2007, 01:22 AM
Tech Resident
edelbrocks are very nice from what i've heard. they don't look as pretty as pacesetters, but when you compare them side-by-side, the edelbrock's are so much larger and look so much better made. pacesetters are a great value, but they're made in mexico whereas edelbrock's are made in america. the edelbrock's definitely have better quality control, plus they have better merge collectors. i think this slip-fits have high velocity merge collectors, but they're known to leak in the non-fully welded version.
IMO, the edelbrock's are definitely the better header, but the ti-tech coating isn't as nice as the pacesetter armor coating. just my opinion.
Old 01-01-2007, 11:38 AM
stock00WS6's Avatar
I have pacesetter LTs, I have no problems. They hang kinda low but my car is lowered, but I'm very happy with pacesetter.
