Generation III Internal Engine - new timing chain for new cam is it nessesary?
Abdullah
12-31-2006, 01:58 AM
i'm doing heads/cam swap and i'm putting a new TSP 233/239 cam in, is it OK if i use the old timing chain?
thanks.
Asmodeus
12-31-2006, 02:10 AM
It's possible to use the old one. If you can get an LS2 chain, it bolts right up and is noticeably thicker. If not, people reuse the stock one too.
white_camaro
12-31-2006, 02:15 AM
depends on if you drive it daily and how many miles you have on it. i have the same cam you have and i reused my old chain, of course i only have 41k miles on my car and drive it less than 1500 miles a year. i think using the old chain will be fine, usually people change them out because youre allready there anyway so you might as well throw in a beefier chain.
white_camaro
12-31-2006, 02:19 AM
what heads you going with? what valves and are you having them milled? sorry for all the questions im just trying to figure out what i want to get for heads in the future. im leaning toward the 5.3's.
Oh4GTO
I vote for a cahnge. When I did my swap the first time I had 6K on the car. The chain had noticeable slack in it. It was about a degree or two. When I did my second swap I threw on a double roller. But the LS2 chain will work perfectly. Its a small price to pay for such an important component.
99stealthta
12-31-2006, 02:41 AM
is it OK to use it? depends, if you have anymore than like an eigth of an inch of play, i would say no go with an ls2 chain. slack is not your friend. Also, to save future trouble go with the ls2 chain.
Slowhawk
12-31-2006, 08:01 AM
thanks.
I wouldn't :)
nikon1999
12-31-2006, 08:06 AM
when your spending hundreds on a swap, whats another hundred for a new chain? good piece of mind and cheap insurance in my eyes...
Abdullah
12-31-2006, 08:48 AM
thanks for the replies. looks like i will go with the old timing chain. the reason i'm going with the old timing chain because i tried to lower the oil pan (and i couldn't) to remove the oil pump to put the new timing chain in and i couldn't so i said to my self maybe it is OK to go with the old timing chain as some of you stated it is OK to go with the old one.
PREDATOR-Z
12-31-2006, 08:54 AM
Good luck! I would change the chain, especialy with an M6 and the way you guys drive in Kuwait :jest:
Eid Mubarak
white_camaro
12-31-2006, 10:17 AM
it is cheap insurance but i think youll be allright.
hazard2k
12-31-2006, 10:25 AM
Dont go lazy on the timing chain. If you dont want to fork over the money for a double roller, at least go with the LS2 chain for 30 bucks. 30 bucks now, or a new engine when your slamming gears and the chain breaks? Your choice i guess
mpsoldier
01-01-2007, 05:49 AM
dumb question I guess, but do you reuse the stock gears when switching over to the LS2 chain?
Abdullah
01-01-2007, 06:49 AM
i think yes, they reuse stock gears when switching to LS2 timing chain.
bfhawki
01-01-2007, 07:38 AM
I vote that you change the chain especially since you are already there. Cheap insurance.
vettenuts
01-01-2007, 08:05 AM
And since you are in Kuwait, pick up a couple of extra o-rings for the oil pump just in case you pinch one. Might save a lot of aggravation and they are cheap.
Slowhawk
01-01-2007, 08:37 AM
It's your car :)
connecticut
01-01-2007, 10:44 AM
looks like you need to spend some more time on the oil pan bolts and get in there
I've been to Kuwait twice, I remember traveling some of those highways, LS2 chain is looking good now
