NEED HELP! what does this mean?
Old 01-01-2007, 12:42 AM
99Transamls1's Avatar
Default NEED HELP! what does this mean?
I got into my car this morning and started it up and the only gauges working were my oil battery and rpm my lights that are on are check gauges, absinop, service vechicle, airbag, service engine soon was on anyways because I havent got my back 02's deleted(but started blinking a couple of times). I started driving it and it started working, then it stopped again. I pulled over turned my car off and re started it and everything was working again a few minutes later it stopped. Now it has stopped and will not work. I the fuses in the driver door and the two boxes under the hood and no fuses are blown. Does anyone know what this means?
now everything is still not working but my check engine light is off and my alarm will not activate but goes off periodically and when I takes my keys out and radio will not turn its self off. Damn I dont know what is wrong
Old 01-01-2007, 09:26 AM
well i got in my car this morning and it wouldn't start so i jump started it and when i turn the ignition off and took my key out it was still running. I had to put my key back in and turn it on and back off for it to die.
Old 01-01-2007, 10:07 AM
well my battery is dead so the frist thing I am going to do it get a new battery. I think I might get a new ignition switch too. Could a short in the igition switch cause all this?
Old 01-01-2007, 11:08 AM
03 BUSA's Avatar
Sounds like it is just a bad cell in your old battery. I have seen 12 volt systems do some wierd things before. Replace with new one and all should be like new again.
Old 01-01-2007, 05:49 PM
replaced the battery still doing the same thing. I am hearing some clicking noises from the fuse box under the hood. It sounded like it was coming from the ignition relay so I replaced it and that wasn't it. still clueless?????
Old 01-01-2007, 06:04 PM
tomorrow I guess the next thing to change will be my iginition switch.
Old 01-01-2007, 07:26 PM
Doc
Doc's Avatar
Couple of things to consider...you said you r/r'd the ign relay correct? Well what about the starter relay right next to it? Iv'e seen similar symptoms and just swapped the relays and that's all. Just oxidation. Second, did you have any build up of acid on the cable(s)?
Old 01-02-2007, 06:44 AM
No no acid on the cables, no I havent replaced the starter relay because I figured it had to something with the ignition since my car was running with the ignition turned off and the the key out. I am going to get a starter today and I will see. thanks
Old 01-02-2007, 07:30 PM
well got a starter relay and still doing the same thing next thing to do is ignition switch. Sucks they had to bolt it above the sterring column, this will be fun.
Old 01-06-2007, 07:47 AM
well it wont hook up to anything to read it so I took it to the dealership and they said I need a new PCM!!!! told me it will be $600 Well I wont be getting that new cam I wanted
Old 01-06-2007, 07:58 AM
najss's Avatar
i had about the same thing happen to my car but it cured it when i got a new battery. not sure what to tell you if the new battery didnt help
TAQuickness's Avatar
PM wait4me. Jess has replacement PCM's for a fraction of that cost.
Old 01-06-2007, 08:44 AM
DRIVER456's Avatar
I bought one from Jess for about $100 real nice guy to deal with..................Paul
Old 01-07-2007, 09:58 AM
yeah I konw a guy that can get me one for $130 thats NAPA price for him. but the dealership said if anything went wrong with it again they wouldn't warranty it
Old 01-09-2007, 07:50 AM
sold the case it was a bad pcm water had rusted my ends together.
