Need a little help with tranny removal (yea i searched)
Old 01-01-2007, 05:21 PM
JSmee99T/A's Avatar
Default Need a little help with tranny removal (yea i searched)
I took all of the bellhousing bolts out and all the electrical is out. I read that theres 3 torque converter bolts that need to be removed but I dont konw where those are. Are they the ones on teh flywheel. the starter is off also. The friggin thing is tough to get out so i read and have tried but I was wondering if i missed something. I didnt want to be prying on something that was still bolted down. We also took out the two bolts running from the bottom of the housing toward the top of the car. Their fairly long but that didnt help. I have pictures too but Im sure those of you who read this or have done this dont need them.
this is where the plastic thing and the starter were.
you can see the whole where one of the two bolts was located that we removed.
Old 01-01-2007, 05:31 PM
LS1Tech Sponsor
performabuilt's Avatar
did you get the three very difficult bolts at the top of the bell
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 01-01-2007, 08:18 PM
Gilbert@Ace Racing's Avatar
The two bolts that you removed were Engine Oil Pan Bolts.... they do not need to come out to remove the transmission. Be sure to get them back in and properly tightened.
Rotate the engine in while looking at the flexplate through the starter mounting location. You will see the converter bolt heads as they come into view. Remove them one by one and you'll be fine. When you are sure all of the mounting bolts are removed then you will need to pry the engine and tranny apar. There are steel dowels/ loactors that tend to be difficult to get the tranny off of. Don't be afraid to pry, but pry evenly from both sides.
Yes the trannies in F bodies are not any fun to R & R. They are difficult even when up in the air using a hoist and tranny jack. Good luck
g
Old 01-04-2007, 02:47 PM
JSmee99T/A's Avatar
thanks alot, how heavy are these?
Old 01-04-2007, 09:11 PM
The1N_only's Avatar
Ive gotten too good at pulling the tranny in and out of my car... and i have soild motor mounts too. The last time i put my tranny in, out the box and driving down the road in 3 hours and thats putting the tail shaft and bell housing on.
Old 01-04-2007, 10:07 PM
ROLLN's Avatar
this write up helped me alot
http://modernmusclecars.net/forums/a...p?do=tcinstall
Old 01-04-2007, 10:13 PM
I don't have the weight numbers in frt of me.... but I believe I once read that they are 125lbs dry. Don't hold me to that though. And the converter is about 25lbs or so dry. I believe.
Too heavy to try to lift it into place while laying on your back if that's what you are asking! It's not the weight, it's the fact that it is so bulky.
g
Old 01-04-2007, 10:15 PM
The1N_only's Avatar
with the converter installed, i would say its probably closer to 160-165
Old 01-06-2007, 01:57 PM
JSmee99T/A's Avatar
Thats not too bad, Its taken me a little over 3 hours so far lol more like 8 and its not even out yet....your replys are appreciated thanks guys.
