How much rwhp estimated?
Old 01-02-2007, 02:44 PM
o-ss-kar's Avatar
Default How much rwhp estimated?
Hi guys.
I try´d the serch button but wasnt any closer at all
say im very new to all of this and the question is
how much rwhp would you say,
with Procharger P1SC ,Twin Intercooled (7psi)
and almost stock everything in a LS1 ?
This is a M6 car with Hooker LongTubes and a Borla Catback.
And allso if i wanted to be able to move it up to (10ps1)
Then what would be needed to do ?
Plz someone input something helpful here
Thanks.
Old 01-02-2007, 03:03 PM
REDCYCLE13's Avatar
460-470rwhp
A fuel pump would be needed to run 10lbs.
Old 01-02-2007, 03:56 PM
o-ss-kar's Avatar
ok upgraded fuel, but would the motor handle 10 psi ?
Thanks
Old 01-02-2007, 08:06 PM
7 Second Club
BlwnTA's Avatar
Only with a most excellent tune! 8lbs would be the max I would recommend unless you are an expert tuner or know some who is.
I made 521 to the wheels at 10PSI, 587 at 12PSI then I cracked a couple ringlands on the stock motor. It's all rebuilt now, see sig. I knew I was pushing it and the tune was close but not perfect. You should see an easy 450, maybe more. That would be alot fun for awhile.
Thanks
Old 01-03-2007, 02:40 PM
o-ss-kar's Avatar
Thank you for that input.
Do you guys have any resepie for what i would need to run 10psi?
and allso for the tuning part..
Im from Iceland , and there are no tuners here, could i send my cpu to the states and get a tune that way ?
Help a newbie out
Thanks again.
Old 01-03-2007, 10:48 PM
slowtealz28's Avatar
Phew BlwnTA, how big of a shot are you running? Is 14lbs pretty much the max boost from the D1 on pump gas???
Old 01-04-2007, 04:31 AM
EPP
EPP's Avatar
I don't recommend going over 8 psi on a stock bottom end, unless you have access to good 93 octane or higher fuel, and have the funding necessary to rebuild the engine should a piston ringland crack. Bob
Old 01-04-2007, 10:34 AM
o-ss-kar's Avatar
I have LQ4 6.0l iron block
But what about the tuning ?
Any adwise would be grateful
Thx guys so far.
Old 01-04-2007, 11:26 AM
Phoenix_Master's Avatar
a mail-in tune is not what you would want. You can either learn how to tune (check the PCM forum for info) or keep looking for someone who knows how to in your area.
It not as hard as some people would come to believe.
Old 01-04-2007, 11:51 AM
o-ss-kar's Avatar
Can it be done with DiabloSport, Predator Programmer ?
Would you recommend D1SC or P1SC ?
And here´s the best part...
What is actually done when you tune a car ?
Thanks again
Old 01-04-2007, 12:07 PM
Rickys S/C Z28's Avatar
hptuners or efi live is the best from what iv read
Old 01-04-2007, 02:41 PM
Thanks again
Those you mentioned are handheld programmers, they can get the job done but I wouldent suggest them for FI, try EFI live or HPtuners either one is great and are limitless to the extent of adjustments you can apply.
What is done when tuning a car? It's mainly correcting the A/F (air/fuel) ratio and advancing/retarding spark timing.
Till now there is no complete guide on how to tune engines (not that I know of) but here are some nice links I've found that will surely help:
*LS1TECH - Finally, How to Tune 101!
https://ls1tech.com/forums/showthrea...9&page=4&pp=20
*New to tuning? Step inside - HP Tuners Bulletin Board
http://www.hptuners.com/forum/showth...?t=3833&page=1
*READ ME!!! All tuning info and how-to's
http://www.hptuners.com/forum/showthread.php?t=4742
*Marcin Pohl's Blog (Redhardsupra)
http://redhardsupra.blogspot.com/200...ity-works.html
On the matter of which SC head unit you want it depends on your goals, contact Bob of www.exoticperformanceplus.com.
Old 01-04-2007, 04:49 PM
o-ss-kar's Avatar
Thanks allot for that input!
Now i need to pull out my dictonary :p
But what would you recommend , P1SC or D1SC ?
And last , what would i need to do to get 10psi , maybe more ?
Thanks again guys!
Quick Reply: How much rwhp estimated?
