Driver door porblem
Driver door porblem
has anyone had a problem with the retaining clip that holds the door skin to the door frame breaking? this clip is at the top of the door underneath the door panel. my clip has broken and through opening and closing the door/ vibrations the glue used at the factory to hold the skin to the frame has come loose. now i have to push the door skin tight to the door to open it and it sucks ***... good fix? replacement part?? location?? thanks...
Similar problem here, but not sure if it's the same as the clip your talking about. My rubber weatherstripping (between the door and window when looking from the exterior) pops up whenever I closed the door. The part inside the door where the clip connected was stripped because of me pushing it back in whenever it popped up. It took a little patience, two part epoxy, and an industrial syringe to get the clip(s) to stay put on the inside of the door. Hope that helped a little, and welcome to ls1tech
i work on helichopters and we have some really killer epoxies there and it always pops loose eventually... i gotta change that clip, or repair it somehow. the clip ( for lack of a better word) is about even with the side mirror at the top of the door, inside the door panel but is not actually part of the door panel. if you pull you stripping back a little that is attached to the door skin in that are you can see it. Thanks for the welcome by the way, this is a killer site.
i have the same problem on both doors, the ends where the door closes are open all the way down. on my other t/a the metal clip on the inside weatherstrip with the window would always pop loose.
i wonder if i use the epoxy you guys listed if i could seal them good, and line it up with the door and body, as at the moment it sticks out about a inch.
any pics of the end result of the epoxy?
