which side Pilot Bearing?
Old 01-03-2007, 08:23 AM
Jeff Smith's Avatar
Question which side Pilot Bearing?
I have trouble to pick correct side.
Which side Pilot Bearing to install toward the Crankshaft?
http://i98.photobucket.com/albums/l2...BlueV-6073.jpg
http://i98.photobucket.com/albums/l2...BlueV-6075.jpg
Which #73 picture or# 75 picture should be toward the crank?
Please help me...
Old 01-03-2007, 09:09 AM
SladeX's Avatar
I think it's pic 75 towards the crank, I vaguely remember hitting in the new one using a socket and remarking how I "dented" it. My original stock one could have been mistaken for a new bearing considering after 55k it still looked new.
Old 01-09-2007, 05:19 PM
heimbo's Avatar
bump, I'm having the same dilemma
Old 01-09-2007, 06:55 PM
Phlip00WS6's Avatar
Number 75 is towards the crank... otherwise the input shaft wont be easy to get in.
Old 01-09-2007, 07:20 PM
myfast70's Avatar
Picture 75 groove goes towards the crankshaft. If you install it with the groov out, it will make removal difficult later on.
Old 01-09-2007, 08:20 PM
connexion2005's Avatar
75 towards the crankshaft and 73 towards the rear. Just use a hammer and lightly tap the bearing into the crankshaft.
Josh
Old 01-09-2007, 09:46 PM
Kleeborp the Moderator™
MeentSS02's Avatar
I went off of these instructions:
http://www.ls2.com/boggs/torques/clutch.htm
...so I installed it backwards from what people in here are saying. Worked for me though, and certainly hasn't caused any problems. I'll have to see if it is harder to get out when I do my next clutch swap...
Old 01-10-2007, 04:49 PM
Phlip00WS6's Avatar
Those instructions also say to put it in the same way..
NOTE: Make sure you install the new bearing with the beveled side out and flat side in towards the crank. Seat the new bearing and tap into place with a hammer and socket or pipe. Hammer the new bearing in until it is flush with the inside of the crank.
Old 01-10-2007, 05:00 PM
MeentSS02's Avatar
I interpreted it to mean the opposite...otherwise, the note above it wouldn't mean anything:
NOTE: Do not use anything smaller then the outside edge of the bearing, because hammering anywhere else on the bearing will damage it.
If they are saying that, then they are talking about the picture in .jpg 75 since that would be facing out (and thus be the hammered surface). The other side wouldn't matter since the inside race isn't visible (and thus you wouldn't have to worry about smacking it with a hammer).
Either way, I'm the one that put it in opposite from what everyone is saying. I probably did it wrong, but I'm not sure what the effects of that decision will be.
Old 01-10-2007, 09:14 PM
2000TransAmWS6's Avatar
^ hey man, i just finished my clutch install today, and i had put my pilot bearing in backwards too... my friend that owns a transmission shop said that it wouldn't have any negative affects, the bearing will just ride i a different place on the tip of the input shaft, and it will be harder to get it out next time, but that it would be alright.
Old 01-10-2007, 09:59 PM
MeentSS02's Avatar
I don't see how it will be any harder to get out...the pilot bearing puller I used just clamps on the inner race from the center, so it should still pull out just fine. I dunno...I'll find out one of these years, cuz that **** ain't coming back out until it has to
Old 01-11-2007, 10:00 AM
my puller tool must be different... but i agree, i hope it is a long time before i have to find out how hard its going to be to get out!
Old 01-11-2007, 02:02 PM
8a8mfh's Avatar
75 goes in the crank, 73 has a rubber seal in the ID, the seal keeps grease in and dirt out, thats the easiest way to tell.
Quick Reply: which side Pilot Bearing?
