finally dyno tuned-good news + bad news
Well, I finally made it to a dyno to get this thing tuned. Put down a whopping 456 rwhp and 498 rwtq. Doesn't sound so good, does it. I know everyone just looked at my sig, and is thinking that sucks. BUT, here's the kicker....that was only at 5 psi!!! My single walbro just isn't cutting it right now. This thing is going to be an absolute animal once I get the fuel setup.
Fuel pressure was dropping from about 62 psi down to about 38 psi throughout the run. And we just couldn't get it any richer at higher boost levels. The car pulls pretty frickin hard right now too, so I'm excited to get the fuel done. Thanks to gtodoug for the help getting this thing runnnnnin!!
Anyone have some suggestions on a fuel setup?
Yeah I know. I just ran out of money to buy this stuff. Hopefully in the next few months I'll make some money, and finish this thing up. I'm hoping to get 15 psi into this thing once it's done!!
Yeah, it's a single 255. I thought we would be able to get it over 500 rwhp too. But, we couldn't even get close. The fuel pressure would just drop like a lead balloon.
tt427ls1, your observation is exactly why I'm actually excited about these numbers. Did I want higher #'s? Sure. But at only 5 psi, this car is rippin!
I'd really like to see where you go with this upgrade.
I think you're doing great for the low boost.
Jim
Jim
A single 255 with 60# injectors isnt gonna cut it. Im running a dual 255 intank setup with no problems. Make sure you run some new wires and good relays to make sure there is no voltage drop at the pump.
TT-TECH Veteran
Jeff
With fuel pressure being so low, I would not go wide open throttle until you get the fuel system upgraded. I would go with a system like what we did on this Trans-Am. http://www.exoticperformanceplus.com...Car.php?car=42 Bob
do you have your fuel pressure regulator set up as boost referenced? that should help along with a boost a pump.
I'm going to be doing that to my car once i break in my new converter.
I think you're doing great for the low boost - I'm assuming that's at the motor, right?
Jim
Jim
Thanks everyone for the help. Bob, when we saw fuel pressure dropping that much, it was at 7.5 psi. We turned the boost back down to make sure fuel pressure remained constant.
Maybe my tax return will be good this year???
I have an LPE/Walbro pump and although LPE says it's good for 600 horses, my car couldn't do over 480 rwhp at 6K before pressure started to drop, pretty much like yours did. The solution was to install a Kenne Bell Boost-A-Pump, and now my fuel pressure is rock solid all the way up to 6600 rpm.
that still sounds low to me for a 370 with an upgraded turbo with heads/cam.Unless the motors not making much NA thats not alot of hp/psi.i could be wrong,whats your CR?sounds like a nice setup btw
EDIT...did some backwards math the cars only making ~340rwhp NA.Low compression?
my car made 503rwhp with 5.5 psi and on 1 single walboro. if i woulda fixed my exhaust leak, i would be 550+ with my extra 2psi. i have confidence with your set up that you'll get more
