how much boost can I get without belt slippage on a stock 8 rib setup
Old 01-08-2007, 02:56 PM
lmt0705's Avatar
Default how much boost can I get without belt slippage on a stock 8 rib setup
I want to run 14 to 16 psi on my next motor and I was wondering how many of you guys are doing that on the stock 8 rib d1sc belt setup, what are you guys doing if you are getting belt slippage? I talked to bob and the guys today and there going to get back to me on a pulley they had made up, but I forgot to ask bob how far I can go with the stock setup
Old 01-08-2007, 02:57 PM
GrannySShifting's Avatar
8 lbs reliably. Yournot goign to do much more than that reliably, I dont care what pulley youhave
Old 01-08-2007, 04:45 PM
lmt0705's Avatar
i was actually running just under 11psi this summer with no problems, I just dont know if I can go any further than that, or how much for that matter
Old 01-08-2007, 09:58 PM
what kind of power was it making? Stock longblock 550-580 should be, cam about 640, h/c 700
Old 01-09-2007, 05:34 AM
EPP
EPP's Avatar
With a larger crank pulley, and a different inlet filter assembly, we have done 16 psi without any problems. http://www.exoticperformanceplus.com...Car.php?car=42
I believe ASP http://www.aspracing.com/intro.htm is now making a larger crank pulley for the ATI ProCharger systems. Bob
Old 01-09-2007, 08:30 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Hey Bob, looks like the sig gods got you.
Old 01-09-2007, 09:17 AM
EPP
EPP's Avatar
Unhappy
No doubt, what a shame! Bob
Old 01-09-2007, 11:28 AM
Brent@LPE's Avatar
LOL that will teach him!
Old 01-09-2007, 11:38 AM
lmt0705's Avatar
i made 475 on bobs eddy current dyno on a 90 degree very humid day with a very safe tune, so that would have been around 515 or so maybe on a dynojet. these guys are way to sharp to not see belt slip on there dyno, and ive never seen any signs of it
Old 01-10-2007, 12:33 PM
SP Motorsports's Avatar
we tested it out for procharger and we went 19.9 psi with stock bracket and stock pulleys we added an adjustable brace frome the j-bracket to the motor to get rid of boost flex..
Old 01-10-2007, 02:44 PM
lmt0705's Avatar
you ran 20 psi with a totally stock setup and no belt slippage?
Old 01-10-2007, 03:09 PM
BIG BAD BLACKSS's Avatar
I can see with a big crank pulley, and a bigger blower pulley to match, all that extra material for the belt to grab has to help out quite a bit.
Old 01-10-2007, 03:58 PM
7 Second Club
ty_ty13's Avatar
i wanna know about the extra brace...
Old 01-11-2007, 08:44 PM
lmt0705's Avatar
me too! but do I need it or just a bigger crank pully? or neither?
Old 09-18-2007, 04:09 PM
BlkHwk's Avatar
Old thread yea, Interested in more info about this brace.
Old 09-18-2007, 05:41 PM
koji777's Avatar
15 psi... no probs here
Old 09-22-2007, 01:48 PM
lmt0705's Avatar
a d1 has to work a lot harder to get that 10 -20 psi. Ive got an sdce setup now and would recommend it to anyone!
Old 09-22-2007, 03:06 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
I did 14psi on a 7.65/3.40 stock 8 rib pulley combo with a P1SC with the hat off and no slip. With the hat on the P1, it made about 12psi without slip.
I am now getting 14psi with a 7.65/4.25 stock 8 rib pulley combo with the hat on the F1 and no slip.
Old 09-22-2007, 03:23 PM
Jake@EPP's Avatar
The key thing everyone is the filter, if you go ahead and ditch the stock filter and swap the larger one we have found to work, you will either pick up boost or make the blower work not as hard.
The inlet tube is not so much a total restriction, but the factory filter is when you step pulley sizes.
Old 09-22-2007, 06:33 PM
speedracer5532's Avatar
I have ran 17.5 lbs reliably on ATI 8 rib 7.625 crank pulley, ATI bracket/tensioner, and 4.0 inch blower pulley
Quick Reply: how much boost can I get without belt slippage on a stock 8 rib setup
