Is This Cam Good For My Setup?
Old 01-12-2007, 07:27 PM
lewroe's Avatar
Default Is This Cam Good For My Setup?
I'm boosting a 5.3 with a typhoon intake with a garrett gt4594. I want somthing mild. Titanium valves, mild port. Going in a 240 with a full manual auto.
Duration at .050 intake 215.0,exhaust 219.8 Valve lift w/1.7 rockers intake 0.598, exhaust 0.551 lobe separation angle 117.8
please tell me what you think.
Old 01-13-2007, 09:30 AM
JPH
JPH's Avatar
diffentley a turbo grind cam, yeah looks good. the only thing i don't like is the titanium valves, atleast on the exhaust side. i would change the exhaust valves over to stainless, if it was my motor.
Old 01-13-2007, 09:44 AM
lewroe's Avatar
why on the valves?
Old 01-13-2007, 09:49 AM
JPH
JPH's Avatar
why on the valves?
high exhaust temps and titainum don't mix very well. the life expectancy of the exhaust valves will be reduced.
Old 01-13-2007, 09:59 AM
lewroe's Avatar
good info thanks, hows the valve overlap?
Old 01-13-2007, 10:03 AM
JPH
JPH's Avatar
looks fine.
Old 01-13-2007, 11:12 AM
lewroe's Avatar
I think it's -18.2.
Old 01-13-2007, 11:29 AM
JPH
JPH's Avatar
I think it's -18.2.
got a copy of the cam card close to you? i will tell you what to look for.
Old 01-13-2007, 11:55 AM
lewroe's Avatar
no, I dont have the caRD. I found a calculator online that used duration and lsa....
Old 01-13-2007, 12:12 PM
JPH
JPH's Avatar
those calculators are close enough, nothing beats the actually card, and then degreeing it in to make sure the the open/closing events are where they need to be.
Old 01-13-2007, 06:23 PM
stevieturbo's Avatar
does anyone even make titanium valves ?
Old 01-14-2007, 11:19 AM
lewroe's Avatar
Delwest, nascar stuff.
Old 01-14-2007, 12:10 PM
RedHardSupra's Avatar
http://www.delwestusa.com/manufactur...ium_valves.asp
Quick Reply: Is This Cam Good For My Setup?
