Adjusting McLeod MC problem
Old 01-15-2007, 03:12 PM
iGoRa's Avatar
Default Adjusting McLeod MC problem
I have McLeod MC installed with new rebuild kit. Bled the clutch.
Now after driving for a while clutch start grabbing lower, lower, finally car stuck in the gear. Fluid check - maybe few drops less than full.
Opened bleeder screw on slave and air got sucked in. Now while bleeding air comes out with little bit of fluid and next time I open bleeder - air sucks in again. Fluid at the reservoir stays at the same level.
wth?
I tried , to adjust the rod within an inch doesnt make much difference.
Old 01-15-2007, 09:52 PM
wrencher
wrencher's Avatar
Did you rip the seal on the rebuild?
Did you try to hone the master's bore w/ a wheel cylinder hone?
There are quite a few posts on the McLeod rebuild in here if you search for 'em.
Old 01-16-2007, 07:56 AM
warp10's Avatar
I have to rebuilt mine every 8 months or so.
Old 01-16-2007, 11:30 AM
iGoRa's Avatar
Rebuild kit came with no instructions, but I put all internals in the way it was.
Update: I pulled clutch pedal with my hand and boom – it started working , fluid level dropped and clutch is operational again. Now I found that quick disconnect is wet, its probably has a small leak but master failed to suck fluid from reservoir and creates a vacuum in the line. When I pull the pedal with my foot or play with it – its getting better and fluid level drops the way it should. I think the piston is not operating in the proper range in the cylinder and somehow blocking fluid inlet hole.
Questions: How much thread do you see on your MC Arm?
Is it supposed to be some play at the top or pedal should be firm all the way?
Old 01-17-2007, 07:55 AM
wrencher
wrencher's Avatar
I'd keep an eye on the fluid & how the pedal acts. I also flush my fluid semi annually or on sight.
If it's getting dark I flush it, saves alot of problems for my McLeod master.
I like to adjust them to have a little play at the top of the pedal, so it doesnt put pressure on the slave.
Old 01-18-2007, 10:07 AM
iGoRa's Avatar
Found the problem , darn thing had a small leak by the master-high press hose connection. Had to pull it out and replace that small o-ring. Seems to be fine now.
Old 01-18-2007, 07:57 PM
Schantin's Avatar
I have play at the top of the pedal travel range too. Nothing to worry about.
Old 01-18-2007, 08:13 PM
Bandit28's Avatar
does the ls6 MC work with the lt1
Quick Reply: Adjusting McLeod MC problem
