PRC 5.3L Stage 2.5 Heads, questions
I have decided to go with these heads. My cam specs are:
233/239 .595"/.603" 112lsa
What headgasket should I go with? Cometic? GM? If Cometic, what thickness?
Could I mill the heads at all with this cam? I want the most compression I can safely get.
Actually, I spoke with the guys at TSP today. If you decided to use the 2.04" intake valve you will need flycutting. However, if you used the 2.02" intake valve you shouldnt need to. I believe, from experience, that unless you need a custom gasket or special application, the gm head gasket is a better bet. The reason for this is that the gm gasket is more forgiving, and also the gm gasket is less expensive.
jon @TSP is running a bigger cam, the MS3, with those heads with the 2.02" intake valve, on STOCK gm gaskets with NO flycutting....
i myself am going to be running this same set up, MS3 on a 113, stage 2.5 5.3 heads with the smaller intake valve (2.02) and stock gaskets...i could have milled, flycut, and ran a thinner gasket..but ehh, i decided to build something without the need to flycut...
goodluck
goodluck
Originally Posted by bigdsz
I hope you flycut, if you didn't, it's not gonna fit. I have unmilled 5.3's and a Comp XER 228/230 only had .045 clearance, so I had to flycut.
u sure you had to flycut? did you measure or just take someones word?
When I degreed the cam I did a valve drop, 8-10* before and after TDC is when the valves are closest to the piston. I also clayed. You should have minimum of .080 on the intake and .100 on the exhaust. Just because the valve doesn't touch piston when you turn the engine over doesn't make it good to go. Valve float or an over rev can be disasterous.
no kidding...
just wondering how they manage to fit an MS3 but not your cam...what am I missing???
Thanks man
I think the newer 5.3's have more p/v clearance than the older ones, in addition, they have one that they sink the valves even more for increaesd p/v clearance with the larger cams like the MS3. I believe those are the ones that TSP used on the car they wrote about.
Originally Posted by 2 SSlow
Have you bought these yet? if so, keep us updated on your results...you planning on getting it dyno'ed after? I have the same cam, and have been looking at those heads as well.
Same here... let us know how it works out for you, I'm also looking at these for my setup!
i have the same cam on a 114 lsa. i was originally going to go with the 5.3's and run the stock gasket for pv. but after emailing tsp twice about heads without any replies i decided to ask predator-z. he suggested the prc stock valved ls6 heads with a .040 cometic, which is the equivalent to around 61cc. no flycutting and running the smaller gasket should make up for some of the midrange. this puts my static compression ratio at 11/1 and my dcr at 8.1/1. if i mill the heads to 59cc and use a stock gm gasket my scr will be 11.4/1 and my dcr would be 8.4/1, i like that but im not sure if it would clear without flycutting.
With that said, you should be able to safely mill off a few cc's.
Same here, MS3 w/ the new version stage2.5 - 5.3L heads. With GM multilayer metal gaskets. My cam is at 113 and my biatch runs sick!! . She changes lanes in 4th . I sould dyno next week, looking to get 475rwhp with full tune. Im on my 3rd set of GM 3:42 gears in the last month on nittos . I still have the following waiting to be installed: Edlebrock carb EFI intake, Fast Fuelrails, 90mm NK, Elbow and 42lbs injectors. Looking to break 500RWHP !!!
LS1Tech Premium Sponsor
Keep us posted on the dyno numbers 01 Berger!
These cylinder heads can be setup to clear the ms3 camshaft. We only build them with that type of clearance when the customer requests it. I typically try to setup the heads with the valves set a little bit deeper only when we need the extra clearance.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
What kind of times are you expecting with that setup?
