chatter and some other noise!!
ok. so i just put a stage 1 spec in my car. i know the horror stories, but i'm strapped for cash and i needed the car driveable. anyway, i've got about 300 or so miles on the clutch and the chatter doesn't seem to be gettin any better. if anything, it might be gettin worse. and there's also a groaning noise that happens intermittently when letting up on the clutch or puttin the car into a gear. it sounds like it's a rotating part because it sounds like it spins for a few seconds, then stops. it's like a groaning/rubbing sound... i'm at a loss here. any ideas on this one? i need to get this fixed, it's driving me crazy!!!
brand new flywheel. actually, the chatter seems to be getting a lot better. i drove it tonight. but the other noise is getting worse. somethings is definately not right here.
the shim is still in there from the stage 3 i put in before. i had plans for a blower, but decided not to mess with it. i went stage 1 because it was a stock replacement and cheap. what exactly does the shim do anyway?
