Mellings pump Vs Ported Ls6
Old 01-19-2007, 04:21 AM
Flow Wizard's Avatar
Default Mellings pump Vs Ported Ls6
What are the major difrences between the two and wich will flow best for a solid roller motor 7500rpm+
Old 01-19-2007, 05:59 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
You are probably going to want a ported pump. Don't want to go low on that high of a spin.
Old 01-19-2007, 07:00 AM
GuitsBoy's Avatar
Its my understanding that the melling already flows more volume and has a stiffer bypass spring for higher pressure. Ported pumps were the best we could do before aftermarket pumps became available.
Old 01-19-2007, 07:26 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
What is the part number for the mellings?
Old 01-19-2007, 08:50 AM
snketr's Avatar
I didn't know melling had a pump out. I'd def get that one then. Their rep is really good. I've never heard of a melling failing or being weaker than OE. Get the melling and port it if needed.
Old 01-19-2007, 09:09 AM
brad8266's Avatar
scroll down about halfway http://www.ls1speed.com/catagory.cfm...in%20/%20Heads
It comes with high flow/high pressure, no porting needed.
Old 01-19-2007, 09:14 AM
snketr's Avatar
It's even $30 cheaper. That's a no brainer to me.
Old 01-19-2007, 09:26 AM
2c5s's Avatar
Melling #10296
Old 01-19-2007, 09:32 AM
LSWon00's Avatar
There's 2 springs with the Melling a standard pressure and a high pressure spring. From what I've been told is that most stock displacement, or heads and cam cars should run the standard spring which is still higher than the LS1/6 pumps.
Also the Melling has two spots on the back of the pump that have to be ground down a little to work with a double roller timing set.
Old 01-19-2007, 02:31 PM
Dumb Ass Vette Moderator
ls1290's Avatar
Correct. I am using the Melling pump with my double roller.
Keith
Old 01-19-2007, 05:02 PM
JPH
JPH's Avatar
melling #10296= high volume 15-18% more, high pressure.(2 presure spring options)
melling #10295= std. volume, but high pressure 50psi+ at idle.
tsp pump= don't know much about them, but i think they are just a ported stock pump, with a higher pressure or shimed spring.
i would probably use the #10296 pump in your application, if your turning 7500+ rpms, you would want atleast 70 psi at that rpm, and that pump will do that with the red spring in it. as far as clearances with pump to timing chain set ups, all your dbl. roller set ups give you a shim to clearance it away from the pump. it is close, but i have never had one rub.
Old 01-19-2007, 07:17 PM
The1N_only's Avatar
you have to run an aftermarket front cover with the milling pump correct?
Old 01-19-2007, 07:22 PM
brad8266's Avatar
Nope.
Old 01-20-2007, 07:56 AM
JPH
JPH's Avatar
no sir.
Old 01-20-2007, 09:54 AM
firefighter's Avatar
So then you should be able to run it witha QTP gimmick then. Are the LS1/LS2 pumps interchangable?
Old 01-20-2007, 11:44 AM
Honda Hunter's Avatar
http://forums.corvetteforum.com/show...hlight=melling
http://drr.infopop.cc/eve/forums/a/t...2/m/8711073162
http://forums.godragracing.com/viewt...095&highlight=
http://forums.corvetteforum.com/sear...archid=4059757
Old 01-20-2007, 12:04 PM
JPH
JPH's Avatar
these all relate to an old style melling m55 pump, which is used on 1st gen/2nd gen small block motors, it has no relation with the gen3/ls style pumps which are designed totally different. thanks for the info though. i have been using these pumps for a while on lsx motors, and don't have any issues, but 1 complaint about predicted pressures.
Old 01-20-2007, 12:10 PM
I'm new to the LSX world. Had a LT1 C4 for a while so when he said he had never heard of a failure these came to mind.
Old 01-20-2007, 12:20 PM
JPH
JPH's Avatar
simple mistake.
Old 01-20-2007, 07:38 PM
miami993c297's Avatar
From the OEM LS6 to my new melling will never step back:
Christian
Quick Reply: Mellings pump Vs Ported Ls6
