Will a 26x11.5x15 ET fit on a 15x8 prostar?
Old 01-20-2007, 01:18 PM
Midnite_LS1's Avatar
Default Will a 26x11.5x15 ET fit on a 15x8 prostar?
Will a 26x11.5x15 ET fit on a 15x8 prostar? <=== just like the title states...thanks in advance for your replies!
Old 01-20-2007, 05:30 PM
99zman's Avatar
it will fit but it is not the optimum rim size.
Old 01-20-2007, 05:52 PM
SuperZ's Avatar
yes that is fine
Old 01-21-2007, 12:29 PM
SJM Manufacturing Inc's Avatar
You can put many sizes on a given wheel. 8.5" wheels are about the smallest that you should use for that size tire.
Realistically, a 10" wheel would have been a better choice not only considering backspace options (5.5" is not a good choice (only one with centerline and weld though...I'd go deeper IF I built an 8" wheel for an F-body (which I'd never recommend in the first place due to the larger tires you can easily run)
with a larger wheel (and tire you want to use)...the tire will fit better with more stability as well as a better sidewall profile.
