Sneek peek at turbo headers for Chevelle
Sneek peek at turbo headers for Chevelle...Pics
Heres what I been doing this week. Dont look like much, but with putting the body on, and mocking everything up. Thinking what would work best. This is the best I can come up with. What you think??
Ron
Ron
Tht looks graet,I just picked up a 71 also tha I have a 6.0 for and am curious what motor mounts you run and what parts you need to put that tranny in there.Also did you have any problems with the oil pan and k-member clearance.Thanks
Thanks guys! I will be TIG welding the headers. Right now they are just tacked in place.
The mounting plates are from Street & Performance. The Bellhousing is from McLeod. They make a kit to mount the Viper M6 to a LS1 without any modifcations to the trans. The oil pan is a custom made pan from Canton. Holds 6.5 qts. in hte pan, and has a remote filter.
The valve covers are from Speed Inc.
Ron
Ron
Yes, the plugs and wires are on. The # 3 & 4 plug will be a b!tch to get at, but I can get a socket on it. I tried my best to design the headers with everything in mind. Not too easy of a task. But after you figure it out, it isnt too hard to build the headers themself.
Ron
Ron
Originally Posted by nitrorocket
Are they mild steel??
Ron
Originally Posted by matthimself456
Where are the downpipes going to go?
Ron
Ron
Ron
Building a set of turbo headers was the hardest part of my turbo build. I must have tried four or five different setups before getting it right. As it turned out, the answer was right under my nose. I was twin turbo'ing a SBC, and I was staring at a set of stock Corvette LT1 headers when I realized they could simply be flipped over. . They even came with heat shields.
Originally Posted by stealth71
So ceramic coated mild stell is good for turbo headers? I thought they could only be stainless for heat reasons, but it makes sense. That can drop the cost of materials a lot.
Ron
Thats whats the "experts" have been telling me. Dont get me wrong, 321 stainless is probally more durable, but cost 3x the money. I was planning on coating anyway, (to keep the heat in) so I was told that mild steel is just as durable as 321 SS, just less expensive. The only hard thing will be keeping the coating on the headers.
Ron
Ron
321 is very expensive. I have had very good results with much cheaper 304 stainless. I'm surprised that they did not reccomend you use it...
Thanks for the comments guys! More pics to come next week. The headers are being tig up now with the collectors on. I still have alot of fabbing to do, (turbo flanges,WG, DP, etc...) and will keep posting pics until the setup is done.
Ron
