ls1?
ok, things you must know about LS1s. #1 they are overpriced. #2 buy a 6.0 LQ4 truck motor.
now, i know what you are thinking, LS1 is aluminum and you want to keep the weight down. well the cast iron block motors only weigh 70 lbs more. an LS1 will be $1500+ an LQ4 would be from $700 - $2000.
as for the answer to your question.. a LSx motor with a cam and nitrous would easily push that car into deep into the 9s. and still make 15+ mpg
Originally Posted by Sabre002
There is a little more then 70 pound difference from a LS1 to a LQ9 when you are talking a complete motor.
Originally Posted by 12secSS
Look up Dave, that240guy on here, he has a 260Z with an LS1 that runs 12.0s @ 117 and get's 25-30 MPG.
Originally Posted by Cop Car
that might be because of the diffrent accessories. im talking about the cast iron block only compared to the LS1s aluminum block. id like to see someone actualy weigh bare blocks only back to back..
7.2's is low 11's NA already with an old junky Vortec motor he has in their now.
Originally Posted by V6 Bird
I should be able to do that if I can find a scale. I have one of each. 12.0's and 117 is turtle slow I might add.
