LS1's in factory LT1 cars
I'm throwing some things around in my head right now. How hard is it to put an LS1 in a car that came with an LT1? It it pretty simple? If i had both cars there is it just a matter of swapping stuff? Are the K members the same? Anyone have an article or link to this having been done before, step by step directions? anything of the sort will help!
Originally Posted by orangeapeel
Several people on here have LT1 bodied cars powered by LS1's.
Originally Posted by Daez
I'm doing it.. just have to drop my cam in etc. before I drop it in the car. K-member is different btw.
I'm window shopping for mine right now. I already talked to Speartech. They said that they can do the harnesses custom and the LT1 cluster would work, fans would work, fuel pump would work, etc. A little over $500 I think.
Originally Posted by DoesSpeedTurnUon
hmm, so if you just swap the k out to the LT1 car, its pretty simple huh?
If you have both cars side by side you can pretty much swap over the entire harness fuel lines gastank and such (that's a hellva lota work) or like other people said just get a conversion harness from somebody and just plug and play. It's up to you what you want in the end.
Also, if you plan to add a cam.. change your oil/fuel pumps, put longtubes in, or do anything of the sort, do it now, or have it done now. 10 times easier, 10 times cheaper.
