To those running LSK lobes...
Old 01-21-2007, 09:10 PM
Asmodeus's Avatar
Default To those running LSK lobes...
What rockers are you running?
Old 01-21-2007, 09:15 PM
brad8266's Avatar
I dont see the correlation between the two, except that the LSK generally have high lift.
Old 01-21-2007, 09:19 PM
Asmodeus's Avatar
just wondering if people are seeing more needle bearing failures with the stock rockers when dealing with the LSK ramp rates and high lift.
Old 01-21-2007, 09:27 PM
brad8266's Avatar
Ah i see now.
Old 01-21-2007, 09:36 PM
ls1muscle's Avatar
stock
Old 01-21-2007, 09:37 PM
thehammer69's Avatar
I would presume that the rocker would see some additional stress from the agressive ramp rate and high lift. That is why I decided to have the upgraded needle bearing conversion that is offered by Harland Sharp performed on my rockers. I think it's good insurance.
Hammer
Old 01-22-2007, 04:42 AM
DONAIMIAN's Avatar
It would be hard to say if more failures resulted from these specific lobes becasue the rocker failure itself is so widespread. It even happens on stock truck motors.
Old 01-22-2007, 02:50 PM
JZ'sTA's Avatar
I agree with the smerf.
I haven't seen anyone complaining about this yet using LSK lobes.
I have done 3-4 setup's now with stock rockers.
I haven't seen a HUGE difference between the XER and LSK stuff as far as power goes, but I haven't seen any harm either.
I have seen some power gains don't get me wrong just not crazy gains.
Old 01-22-2007, 02:56 PM
LS1 Tech Administrator
Patrick G's Avatar
Stock rockers here. I think you could possibly see less stress on rockers and valves with LSK lobes than XE-R lobes because of the softer ramp rate from .006" to .050". and higher lift. The higher lift lobe actually follows the lifter's intended "loft" angle better than XE-R lobes and the softer ramps at .006" should reduce valve bounce. In my eyes, the LSK lobes shouldn't be any harder on rockers unless you are going way up on spring pressure.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 01-22-2007, 03:32 PM
z28misfit's Avatar
Not to interupt this thread but how do you know if you have LSK lobes.Not real familiar with the whole lobe design.
Old 01-22-2007, 05:19 PM
DONAIMIAN's Avatar
LSK lobes have a lot more lift that normal XE or XE-R lobes. Lift starts at .629 and up.
Old 01-26-2007, 08:05 PM
z28misfit's Avatar
Oh ok , thanks!
