fix door panel cracks...
Originally Posted by XtinctZ28
Where do they crack? I have never seen this.
https://ls1tech.com/forums/pontiac-firebird-1967-2002/440767-cracked-interior-door-panel-don-t-quote-pics.html
Originally Posted by SScam68
I bought new door panels and radiused the notches where the crack starts. Still haven't had a problem.
I posted some pictures, run a search.
Rehab is for quitters...
Originally Posted by toofless916
i posted this a while back and was very depressed but here is everything you need to know about the door crackus...
https://ls1tech.com/forums/showthread.php?t=440767
where did u pick up new door panels from?
attached are some pics of what I did.
Mine were cracked also. I got replacements at e-bay without any cracks. Before installing I reinforced them since they all break at the same damn spot. So far theyre fine. I also try not to lower the window all the way down. This puts a lot of stress into the panels.
Originally Posted by IMJ
i think gm should recall those bastards.
It would fail if we brought GM to court as it doesnt provide any negligence. There is no direct or indirect harm to owner/passengers or surrounding people. Now, if it greatly decreased the ablity to stop a T bone hit from coming into you, when maybe that would be enough negligence..But since its a coupe it relies on the body for that, not the interior...
