possible upgrades?
possible upgrades?
ok, this spring im going to be having my t56 rebuilt getting a new clutch etc. while im having the transmision rebuilt i thought it might be a good time to do a few things to the engine, i was thinking mostly valvetrain such as a set of springs/retainers, rocker arms and possibly pushrods and a mild cam. my engine is completely stock (at least i assume the last owner didnt do anything)i plan on eventually upgrading more of the internals as i get the $$ to do so and i thought the valvetrain would be a good place to start
my question is: what is the difference between single and dual springs, is it worth getting titanium retainers, if i do get rocker arms should i get 1.7:1 or 1.8:1 and what is the diference and what size/brand pushrods and cam should i consider? is there anything else i should consider doing while i have the heads off?
thanks
john
thanks
john
oh also, i know i wont need a tune for the springs/retainers but whould i for the rocker arms? i would def get one if i upgrade the cam (want it running its best )
Ok, the dual spring issue depends on how aggressive the cam is, if its a high lift fast ramp cam then yeah dual springs. BTW if your not gonna swap the heads you can change the cam, springs, pushrods, an retainers without pulling the heads off. Stick with 1.7 RR's too. Titanium retainers are really nice and will work well with any setup.
I would not be stepping up for a cam until I had full exhaust and intake systems already done.
dual springs have a higher lift rate than a single spring. ti retainers help lighten up the valvetrain some and come with most dual spring kits. stock rockers should suffice for whatever cam you choose to get. pushrod length will depend on the size of the cam's base circle. the cam you pick depends on what you are looking for.
thanks guys, alot of useful info, i saw on the ws6 store site the "98-02 Comp Cams "RPM" Valvetrain Upgrade Kits" it comes w/ the springs, steel retainers, and pushrods for around $300 , i think i might get that kit. i'll wait on the rocker arms and cam until i get a few other things done to the car, im doing a catback at the same time but waiting on headers etc till next winter, i might look into doing the intake this spring now instead of the cam. ill also look into the slave cylinder
thanks again
john
thanks again
john
