83% throttle at WOT
Pull the inlet tract into the throttle body so that you can see the throttle blade. Have someone go in and push the throttle to the floor and make sure the blade is open all of the way and that the throttle body cam is sitting on the stop.
If it is not make sure the floor mat is out of the way and that there is nothing binding the cable or throttle cam. If everything is clear then check the TPS sensor and make sure it on correctly. The computer gets it % reading directly from this sensor, if it is bad it could cause a false reading to the ECM.
LS1TECH Sponsor
Originally Posted by pdanrichey
Not sure about the spark advance though...
Look at the log
Look at the histograms
match it to the corresponding tables
you'll then find your answers
Same deal with mine. You need to look at ETC.. thats the real deal.. Never seen above 84 on TPS.. Usually 83 and then briefly to 84 and back down to 83. However, I have a problem with my trans temps showing up as 32 degrees. Whats with that?
This is a 2001 camaro ss m6. Just put ls6 conversion heads and cam. I noticed 80% on efi live and started to investigate. The throttle does not hit the stop, and i saw the stopper on the pedal. ETC is fly by wire, right? I have an actual cable.
