View Poll Results: Which cam
TSP Magic Stick 4
60
33.33%
G5X4
27
15.00%
TRex
46
25.56%
Other(please include which other cam you think is best)
47
26.11%
Voters: 180. You may not vote on this poll
which cam for cam only car?
Old 01-28-2007, 01:15 PM
01FbTaWs6's Avatar
Default which cam for cam only car?
Ok guys, im pretty new to this whole cam thing. I have a 2001 TA WS6 M6 that im looking to go cam only with for the time being. This car isnt my daily driver, its a weekend car, taht will see occasional strip time. Im wanting a cam that is capable of putting me into mid 11's. Right now my car is stock, but will have LT's with Dynomax Bullet Mufflers hung from the collectors, LID, then of course SFC's, TQ Arm, Panhard bar, with a moser 12 bolt, with 3.73 gears. Anyhow, choices are the MS4, G5X4, or TRex
Old 01-28-2007, 01:32 PM
engineermike's Avatar
TRex has the cam-only record. Draw your own conclusions.
Mike
Old 01-28-2007, 01:47 PM
Cop Car's Avatar
G5x4 ftw
there are way to many variables with the "cam only" bs.
i have a G5x3 on 110, i wish i had the x4 though
Old 01-28-2007, 01:53 PM
01FbTaWs6's Avatar
sorry guys, wasnt trying to start a bickering war here
Old 01-28-2007, 02:44 PM
ebear's Avatar
Custom Grind. Call up a shop and tell them your goals.
Old 01-28-2007, 02:58 PM
Evans752's Avatar
If I was going to but one of those 3 it would be MS4. Good luck in your choice.
Old 01-28-2007, 03:32 PM
curtisad's Avatar
The Lunati Voodoo is my choice! Not the most popular, but very impressive!!!
Old 01-28-2007, 03:41 PM
Hype's Avatar
G5x4! LG cams always seem to produce good results.
All have good records, trex has best track record and probably the worst street manners... I tend to lean towards street myself.
Old 01-28-2007, 03:48 PM
01FbTaWs6's Avatar
Yes, street manners are important to me, but I think most of that can be tuned out. Also, I have talked to quite a few people, and everyone has a different opinion, kinda like GM or Ford. Anyhow, I dont think i can go wrong with any of the 3 above cams, so i will choose when the time comes. Thanks for the replys so far guys!
JRracing's Avatar
Can't go wrong with any of them. But all of those are not very street friendly.
Old 01-28-2007, 03:53 PM
RedWS6 00's Avatar
You say "Cam only" do you mean strictly Cam only, then perhaps the ones you suggested will be no good at all. Some of those cams have fast ramp rates and high lift which may be beyond the tolerance of the stock spings. If you are not changing the valvetrain at all it may be safter to go for a mild cam. If you are going dual gold springs with .650" max lift then you have a much wider choice of cams(the ones you suggested).
Old 01-28-2007, 04:16 PM
01FbTaWs6's Avatar
it will have upgraded springs and pushods at the same time. Sorry for not clarifying that.
Old 01-28-2007, 08:40 PM
1CAMWNDR's Avatar
For street manners and big torque/power:
Comp XER 226°/232° 109° +2° (107° ICL). Great dynamic compression, no need to flycut, don't need to rev it to the moon (@6,400 rpm power peak).
That will get you real close to 400 rwhp AND 400 rwtq.
Old 01-28-2007, 09:53 PM
JRracing's Avatar
Thats more like it for a street cam.
Old 01-28-2007, 10:33 PM
His goals are as fast as possible with a cam-only setup. Luckily, a shop already did tons of R&D on just that, and the result was the TRex.
Mike
Old 01-29-2007, 10:55 AM
1CAMWNDR's Avatar
Originally Posted by 01FbTaWs6
.....This car isnt my daily driver, its a weekend car, taht will see occasional strip time. Im wanting a cam that is capable of putting me into mid 11's............
It says here he is not looking to set any records. This is why I think he doesn't need one of the listed cams. And since he has stock heads, I don't recomend the LSK lobes. That XER I spec'd will put him deep in the 11s with the right suspension.
Old 01-29-2007, 11:24 AM
jamesSS's Avatar
i totaly agree. the cams listed are more "strip" cams. i would also look into a custom set-up grind. it will give you the best of both worlds.
of the ones listed, i voted MS4.
Old 01-29-2007, 11:46 AM
99blancoSS's Avatar
With your gears I would run g5x3. Trex wants 433's or 455's or something. Its a weekend warrior so you can go big if you want but you need the gears to support the trex and pro'lly those other 3 as well. If your willing to change the gears then Trex FTW. Otherwise g5x3 234ish/242ish , 236/244 would be pushing it IMO with 373's.
Old 01-29-2007, 08:47 PM
black_z's Avatar
Your going to want more gear for those cams. I went 4.30's with an F13.
Old 01-29-2007, 08:48 PM
caviness's Avatar
I VOTED MS4, BUT FOR WHAT YOU WANT i wouldnt pick any of those cams,maybe 224 or230 the most on 110 lsa of course.
Quick Reply: which cam for cam only car?
