New EFILive Tutorials
A number of interactive tutorials have been produced and are now available from the EFILive Downloads Page
These take you through some of the very common tasks that we perform regularly with our tools. It will also help answer a number of the support related questions.
The list will continue to be expanded.
Configuring the Calibration Display Units
FlashScan V1 Licensing
FlashScan V2 Licensing
How To Calibrate The Speedometer
How to Copy and Paste with AutoVE
How to Create a Filter
How to Create a Map
How to Create a PID List
How to Load a Custom Operating System
How To Perform a Full Re-Flash with Moates RoadRunner
How to Update your V2 Firmware
Installing Drivers for Moates RoadRunner PCM
Read PCM with FlashScan V1 & V2
Upgrading your V1 Workshop to V2
Using the Navigator to Locate a Table
How to Create a Map
Copy and fill
Copies selected MAP cells to the clipboard and fills any empty cells with the average value of its surrounding cells. The “smoothness” of the fill can be controlled with the “smoothing weight” setting in the MAP property editor.
Copy and fill with labels
Copies the selected map cells and their labels to the clipboard and fills any empty cells with the average value of its surrounding cells.
You use copy and fill with labels when doing autoVE for example this allows you to paste with labels (add and multply) pretty much clicking where ever you want in the tuning tool VE table without having to remember or lineup the area you copied from in the scanner
