boost psi
Old 02-01-2007, 09:20 PM
iceman99's Avatar
Default boost psi
how much boost is safe in a stock block ls1
im running the 76mm street tti kit
Old 02-01-2007, 10:01 PM
HAMRHEAD's Avatar
Do a search. There were quite a few threads about this lately.
Old 02-02-2007, 12:37 AM
Snyper's Avatar
6psi.
Old 02-02-2007, 12:55 AM
ninetres's Avatar
Originally Posted by Snyper
6psi.
10
Old 02-02-2007, 01:14 AM
iceman99's Avatar
ok so im definite not going to gegt a straight answer because i have searched and have found anywhere between 6 to 11psi. is it more of the hp level that is dangerous to the motor than the psi?
Old 02-02-2007, 01:36 AM
6techniques's Avatar
Well, youre not going to get a concrete answer on how much boost to run, but like you said, the range is from 6-11 psi. Some people busted their engine at 6psi and some at 11psi and thats the best youre going to get...I suggest you look at not just the numbers but the experiences that went along with them as that will give you a more clear idea of what to do.
Old 02-02-2007, 01:49 AM
iceman99's Avatar
Well damn thats just really sucks off to mti for a shortblock i guess. Oh wait i still have to sell that damn 350z. Should have never bought rice!
Old 02-02-2007, 01:58 AM
Top Secret's Avatar
7 to 8 psi is what I would run on a stock shortblock. If you switch to the truck heads (317's) it will drop your compression by about a point and you could get away with maybe a pound or two more.
Quick Reply: boost psi
