vibration
Old 02-07-2007, 04:09 PM
wpnsman2000's Avatar
Question vibration
does anyone else w/ true duals have a vibration from the pipes hitting the underbody? If so how do you fix it or can you?
Old 02-07-2007, 07:51 PM
Default Anybody
Anybody?
Old 02-07-2007, 08:28 PM
tsench's Avatar
take it off give it to me then it solve ur problem is this over axel ?
Old 02-07-2007, 09:53 PM
Default No
Its dumped!
Old 02-07-2007, 10:48 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Can you tell where it is banging? Most true dual people don't have this problem. What kind is it? Are you lowered? Suspension?
Old 02-07-2007, 11:24 PM
tsench's Avatar
dumped then check your Y on driver side i have same problem move the driver side down a lil then u good to go
Old 02-07-2007, 11:46 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
How many true dual Y pipe setups have you seen out of curiosity?
Old 02-08-2007, 06:11 AM
Default well
I don't have a y pipe or x pipe. Its one pipe form each header its starts at the header goes to the cat and to the muffler and dumped...sounds great just some vibration.
Old 02-08-2007, 09:12 AM
FU_I_AM_UltraZ's Avatar
I don't have true duals, but you have to get better hangers made up that aren't that close to the body or if a pipe needs to be bent downward a 1/4inch, then get it done.
Old 02-08-2007, 08:49 PM
tsench's Avatar
my bad misstake i meant the x from the driver side pipe
