92 LS1 FM T76 Build
92 LS1 FM T76 Build pics
My car is 1992 with the complete drivetrain from a 01' WS6, LS1, M6, and rearend.
I dont know if anyone else is attempting this at this time..I've seen some rearmounts on the LS1 82-92 Camaros but not any FM's. Anyways, making the kit completely from scratch with limited room to mount the Tangential Housing Turbo.
My Specs.
3" Intercooler
Turbonetics T76 tangential with .81 AR
Turbonetics Godzilla Blow off Valve
Turbonetics Racegate Wastegate
Dynojet Wideband commander
going with SD 2 Bar setup.
60 lb injectors
Racetronix pump
2.5" crossover
3" DP
Here are some progress pics. Hopefully I can have this thing running in a few weeks.
where I would have liked to have it but it wouldn't work out.
Cut out my battery tray to make room for mounting plate
My Specs.
3" Intercooler
60 lb injectors
Racetronix pump
2.5" crossover
3" DP
Originally Posted by Beaflag VonRathburg
I've also read about some third gens that have over heating problems because of the intercooler blocking flow to the radiator. Looks good though, I like it.
Thanks guys....Yeah I thought about that when putting it in but I guess I will just have to see....I'll fix it if it gets hot but the car before the intercooler never saw over 180 temp.
OWN3D BY MY PROF!
Originally Posted by super_kev
I would say that it is mainly on the Firebirds/TA's. Camaros have a nice grill that the intercooler can be mounted behind.
700th post = hell yes.
Some new pics....Got all the v bands installed and the flex pipes as well as the wastegate mounted.....The pipes are off now getting welded solid and heat wrapped and prepped for final installation.
