Driveshaft Let loose on Dyno
The other day my steel driveshaft let go on the dyno. I was there for tuning on my 2.73 car with a fresh H/C package. It let go on the 2nd pull@ about 6400rpms and around 400rwhp.
The driveshaft Completely separated from the Tailshaft housing and jammed up in the tunnel. The torque arm took a good hit also.
The car is at the Shop now and they said they could find another tailshaft housing and an Aluminium DS.
I'm just trying to figure out why it didn't let go on the 20 some passes and the 8 months of driving since I had it out. I never heard/felt any weird vibrations except for right before It went on the dyno, on a tight turn out of a parking lot onto the road. I recall it now, but just dismissed it as wheel hop or something at the time.
Do these high powered 2.73 cars have a history of steel driveshaft/tailshaft problems? It's odd that it would let go on the dyno and not on the street. The shop is waiting for the go ahead to fix it but I want to make sure that It isn't something else that I'm over looking.
Well man i am afraid. Things break when they break. no one can say. Ok you have X amout of HP so your tranny is going to go in 1051 more miles. I would say after it was beat on for a while it just let go.
That's what she said...
I wouldn't put a stock aluminum DS in it. Fix it RIGHT while you're at it. Use a 3" aftermarket steel, or a 3.5" aluminum.
The stock steelie shouldn't have broken with that power level and an auto, must have had some sort of flaw that didn't really show itself untill that day. **** happens.
I have this DS myself, barely heavier than a stock 3" Al, and it's plenty strong.
http://www.exoticperformanceplus.com....html?item=541
Damn, that looks like a good investment since my DS is the weak link of my drivetrain now!
i was just curios. torque is what twists or breaks driveshafts. not hp, my other car needs an upgrade and they look like they are of good quality. they didnt give you spec sheet with #s.
Whats the deal with posts I've seen about the steel driveshafts and location of the stock Torque Arm and the cracking of the tailshaft housings on these Autos. Anyone heard of this?
I'll probably end up with a different tranny up there. Just got off the phone with the shop and they said 95% of the time the output shaft gets damaged when spitting a DS like that.
