Which Drag Radial is better
Old 02-09-2007, 11:56 AM
ohsofast's Avatar
Default Which Drag Radial is better
BFGoodrich Drag Radial, Nitto 555R Drag Radial or Mickey Thompson Drag Radial. On my old setup I like the Nittos. I have now added H/C,headers,gears,catback,bumped up my shot,and 4000 stall. Which drag radial works best for you guys. Also they will be going on 17's
Old 02-09-2007, 12:43 PM
nealws6's Avatar
i would go with the BF
Old 02-09-2007, 01:56 PM
can'tfindausername's Avatar
BFG will wear a little quicker but will hook better....so BFG
Old 02-09-2007, 06:18 PM
sleeperstyle's Avatar
the mickey thompsons are the BEST hooking drag radial out there, PERIOD. bfg's and nitto's don't even hold a candle to the mt's. nitto's require a ton of heat to even hook at all, and bfg's wear as quick as the mickey thompsons and don't hook as good.
Old 02-09-2007, 07:39 PM
Old Drag Racer
Smokinstorm's Avatar
what he said^^
Old 02-09-2007, 08:12 PM
GotV-8's Avatar
MT's all the way
Old 02-09-2007, 08:40 PM
Sudz's Avatar
Nitto - Longest life , worst hook/traction
BFG - Middle tread life, 2nd best hook/traction close to a MT when hot/clean
MT - Worst Life, Lots of traction
MT has a slightly softer compound than the BFGs and less tread which allow it to hook up a bit better but the tread wear is somewhere around 2x as fast as a BFG. For a daily driver i would get the BFGs due to wear & tread amount. nittos are out of the question for hooking unless your car is stock.
Old 02-09-2007, 08:53 PM
BlackHawk T/A's Avatar
I agree with the above minus one thing - I would not even use the BFG's on a daily driver, unless you don't mind buying a new set every 6-8k miles.
On that note, I have had my Nitto 555R's on for 3k miles and they still look new, though I haven't spun them that much yet. They don't wear much during normal use and I wouldn't be surprised to see 10-15k out of them which is truly amazing for a tire that hooks like it does when hot. It's a great dual-purpose tire.
However I will be stepping up to BFG's or maybe even the MT when their new version is out. The Nittos are just too easy to spin with this converter, and won't work at all with future plans.
Old 02-10-2007, 06:51 AM
My car has mickey's on it, and I drive with them on the street, they wear fast but hook like no other, so if ultimate traction is your goal....mickey's
Old 02-10-2007, 07:05 AM
Restricted User
2001 Pewter WS6's Avatar
MT's
BFG's
Nitto's
In that order... And yes I have had them all...
Old 02-10-2007, 10:13 AM
ohsofast's Avatar
Does any of our vendors carry the Mickey Thompson's I have found them but not with our vendors. I think that is the tire I am going to go with. Also does anyone have a pic with them on there car w/17's NOT 15's
Old 02-10-2007, 12:02 PM
here are 275's,just getting broke in
Old 02-10-2007, 04:13 PM
ohsofast's Avatar
That's perfect thanks for the pics.
carado1984's Avatar
do they hook well for beinga 275/40?
