For those that have stepped up from 17 inch wheels to 18's, how much traction...
For those that have swapped from a 17 inch wheel to an 18 inch wheel, how much traction is lost (assuming you run similar style tires)? Is it a big difference dropping from a 40 profile tire to a 35 profile?
It's more a function of the tire you buy than the minimal difference in aspect ratio. I went from a 275/40/17 to a 285/35/18 and since the new tires were better I actually had better traction. I think that even give the same exact tire that the difference in straight line traction woulb be minimal if any because there just isn't that much of a change in the contact patch between the two. You can always do like I did and get a slightly wider tire ti make up for any possible difference.
